going CA shopping
dad2many View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Topic: going CA shopping
    Posted: 02 Mar 2012 at 9:09pm
Going to possibly add a CA to the barn tomorrow. Anything specific to check for on these? I've got a B already. Just wondering if there were any common issues.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:17pm
If possible hook to load and pull to check hand clutch for slipping..  Mine slips some as I bought it non running I couldn't check it.    Tim
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:18pm
i do the basics check the tranny gears out ride the brakes rev her a couple times run the hydraulics lights bring a cresent and check the rear end for oil see if there is any or if its bone dry. but most importent for the CA check the hand clutch out good so it is not froze up and not working see how wore everything looks pin wear pivet wear exsedera and thats all i can say  ~AMP~
~AMP~
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:18pm
Yeah, they will be just like my "B"s, ADDICTIVE !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:52pm
Please explain how the hand clutch works
My b doesn't have that ;)
I understand its used when pulling a load plow or what ever, but how do I know if it is working right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 10:03pm
its like your foot clutch but when you use it instead off your foot clutch your pto keeps spinning and you roll to a stop.Smile is very handy i mow with my ca and sometimes when i get into the tall weeds i use the hand clutch to stop the tractor then the foot clutch otherwise the deck plugs up if you stop all of the sudden and roll into the weeds
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote dad2many Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:36pm
Well you can see my success on another post. I didn't find the hand clutch. I found the hydro controls and there is a little ring lever beside it that I haven't figured out yet. 7 hours round trip makes little time to play once home. Plenty of time to play tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:21pm
The little ring next to the hydraulic control lever is the PTO and must be engaged for the hydraulics to work.
This page was generated in 0.127 seconds.
