B WFE on a CA
Kforeal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kforeal Quote  Post ReplyReply Direct Link To This Post Topic: B WFE on a CA
    Posted: 02 Mar 2012 at 5:51pm
Will a B WFE fit my CA.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:22pm
Yes but it takes a little rigging.
cadcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cadcorey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:32pm
It will go on and yes it takes a little work. I am putting one on a C and the biggest thing is the steering arm out of the box. You need to have the one from a B. That is because the C arm has a tie rod end and the B has a steel ball end. You also need the right radiator support. As long as you have all the parts for the front end it should be no problem.
This page was generated in 0.271 seconds.
