mf
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: mf
    Posted: 02 Mar 2012 at 12:33pm
now...i know ya'll don't like Massey's on here...but...was watching utube video's last night, saw a Massey plowing, it was pushing 6 bottoms, and pulling 12-14 bottoms, and it was a 2-wh drive tractor! others had same make of plows and they were roll-over plows, but were pulled by 4x4 tractors of dif makes! i just thought it was pretty impresive! i never seen a plow that you pushed ahead of the tractor before!
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 12:36pm
Link to vid
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 1:03pm
Massy usually wins current plowing competitions.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 1:16pm
   Actually, it was pushing 4 bottoms and pulling 13, In previously tilled ground ?
[TUBE]78ZQAdTQM8A&feature=related[/TUBE]
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 1:22pm
   I bet a 4W305 would pull 24 bottoms in that fluff !
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 1:47pm
No way could you do that in Pa.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 1:50pm
He said it was a 2 wheel drive. That can't be the tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:57pm
yeah...that's a roll over plow in that vid...i watched it too, the other was a 2-wh drive with duals, but it wasn't a roll over plow. even so, it's still impressive, as the plow is still going deeper than what is already tilled. i'll try to find it again....but ussually when i see something once, and try to re-find it....i can't! pffft! i was also impressed with a 4x4 tractor made overseas, i can't remember how to spell the name, but if you google/bing "k700 tractor" you'll see it! and there are vids on it pulling a manmouth mounted plow like 8-9 bottoms. didn't look like it was even working it! looked kinda like an old OshKosh truck with tractor tires!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:07pm
RF...i just watched the vid you posted, it isn't the same one i watched, as i didn't see the re-fueling or night plowing in what i watched, but was same type of ground. sure wouldn't plug up!! i ussually always plug up 2-3 times doing corn stalks with my 6 bottom.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:14pm
 I don't forum member have thing against Massey Ferguson tractors. They just hate the company that makes them.
Edited by DennisA (IL) - 02 Mar 2012 at 5:15pm
Thanks & God Bless
Dennis
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:31pm
Wonder what 251,376 hectacres is in real measurement?
Kurt WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurt WI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:41pm
dipstick i think it would be 532203 acres  Kurt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:43pm
   A hectacre equals 2.471 acres so 251,376 hectacres equals 621,150.096 acres
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:45pm
if i figer'd right....i think it is 621.16367 acres!
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:46pm
It is hectares, my wife say's she says a hectare is 10,000 square meters, or 2.4 acres. Metric
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 5:50pm
1 hectare = 2.47105381 acres
So,   251,376 hectacres x 2.47105381 = 621,163.62 acres
Or    251.376 hectacres x 2.47105381 = 621.16362 acres
Probably the second answer.
Edited by Protrucker - 02 Mar 2012 at 10:34pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:37pm
They must have plowed the same ground over and over again. 621,000 acres doesn't seem right in 24 hours. That's a huge area to run over in that time even at that fast speed.
Wink
I am a Russian Bot
ncrc5315 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ncrc5315 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:45pm
The use of a comma as a decimal separator is common in several European countries. So it would be 251.376 hectares X 2.471 acres = 621.15 acres.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 6:49pm
That number does seem awful large.
I know that it seems like metric measurements use comma's where we use decimal points. I never what is really right with those conversions. Confused
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 7:11pm
That sounds way more reasonable.
Wink
I am a Russian Bot
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 7:48pm
I don't think Massey makes a plow so I doubt they could win plowing competitions.  It's been awhile since I checked but Kverneland used to win them a lot.  Kverneland was recently bought by Kubota.
agcodick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote agcodick Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 7:55pm
That Massey 8280 is the same as an Agco DT-225. I have heard that these tractors are juiced up for these plowing competitions. I think Agco won it again with a challenger tracked tractor a couple of years ago.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:26pm
How can we hate the Allis Gleaner company? It's the current bone headed idiots in controll that we don't like. LOL
So a red DT225 plowed a little under a section with no crop residue and a specially built pair of plows, and with a pit crew that would that would put Indy or NASCAR to shame. What does this have to do with the real world?
AGCO My Allis Gleaner Company
This page was generated in 0.073 seconds.
