roto baler
Ia Jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ia Jim Quote  Post ReplyReply Direct Link To This Post Topic: roto baler
    Posted: 01 Mar 2012 at 10:06pm
I have bought an AC roto baler.  I've never run one and know almost nothing about them.  As soon as I can find a manual I will buy it, and get to studying it.
This one has a white top and white wheels  which I was told makes it a later one. As soon as I get it home I'll check the serial number, maybe someone can tell me what model and year it is.
Does this baler use regular baler twine? If I need a belt, where is a good place to get them?
I'm sure I will have lots of questions and any replies will be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 10:11pm
They use binder twine. Tom Yaz on here should be able to help out with most parts
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 3:26am
I would start by getting a copy of a Manual similar to this one.
This one appears to be an original.
Reprints are available.
BTW you need a tractor with 'live PTO' since you have to stop the forward motion of the tractor while the baler winds the twine on the bale.
Gary
Tim8975 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim8975 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 7:36am
They are also available through AGCO @ www.agcopubs.com. I just recently ordered some and they arrived within a week. There is currently a price discrepancy on one of the rotobaler manuals that I have notified them about. I don't think $1305.00 is correct unless it has gold print. :)
Tim
http://www.allischalmershistory.com (Work In Progress)
1959 AC Series 1 Black Bar Grille D17 Gas WF
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 7:47am
Make sure you have plenty of patience on hand too...you're going to need it. lol
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:12am
I have seen the Roto Baler twine at some of the farm stores around here in Iowa. I think I saw it last summer at Marengo Iowa Farm and Home and just ask at a farm store.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:13am
By the way Jim, I am envious! I would like to get a roto baler someday to go with my WD.
Pastor Mike
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 10:11am
Every time a roto baler post comes up I am reminded of the may bales that I put thru one as a kid...and my older brothers put a lot of bales out the back too. Go, stop, wait for the twine to roll, repeat...gave that hand clutch a workout. We were well warned we did not do anything to the baler unless the power was off...can not say that i did not 'dis-obey' once in a while, lucky and still all here.
Yes you will need patience, and an eye for noticing what the machine is doing...so you can see what it is not doing.
peace
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 3:00pm
If you have any questions on operation I can help you out.  Send me a PM where I will give you my number and I can give you some advice.
Jim
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:49pm
My local Farm and Home store in Creston still stocks twine and belts. I ran over 500 through mine last year and I can say definately get an operators manual. Pay attention to the part that explains how to rake the hay. It makes a BIG difference. The hay also needs to be dry. Like everyone else has said, be patient. I have run 100 in hour or 50 all day so it just depends. There is nothing quite like seeing a field full of little round bales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 9:28pm
like Chris says how you rake the hay makes a big difference.You basically have to rake two rows together to make a windrow as wide as the bales.This way they roll uniform straight bales that wrap and tie much better.I would rake around field one direction and then turn around and rake two rows together.Kind of a pain but makes much better bales.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 6:11am
When I bought mine some 40 years ago a friend who had one said to be sure not to have matches or dynamite handy or you may be tempted to use them.
This page was generated in 0.110 seconds.
