b vs c
ewbs79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Topic: b vs c
    Posted: 01 Mar 2012 at 7:17pm
Ok I have my b going and I also have a c that is next to get running I know the c is a touch bigger but does it have more hp? Not really sure the differences between the b and c is basically what I would like to know if some people care to help a dummy out
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:23pm
B and C have pretty much the same motor and HP if not identical.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:28pm
Yup, identical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:36pm
Same motor. Different gear ratio and maybe a little more weight on the C will make a slight difference. Both are handy little tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:42pm
I know the c is wider. Is 1sta gear. Slower
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 7:42pm
Final drives are the only major difference as the C is geared a bit different.Engine, sheet metal and transmission are the same
Charlie
Protrucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:19pm
According to Tractor Data, The C has more horsepower.
B
Drawbar power (max): 12.97 hp
C
Drawbar power (max): 18.4 hp
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:19pm
Except the radiator shroud.
 The B was a one row tractor and the C was a 2 row tractor, speaking of cultivating anyway. All B's had a wide front end, C's could be single,narrow, or wide front. I think you might find most C's had foot brakes and electric start because they came out later than the B. Early B's had no starter and hand brakes. The back wheels of a C had a wider stance than a B because of different length of the final drive. The drawbar on a C is a wider arch than a B to fit the wider final drives.
 OK what else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:25pm
B
C
The B test was done in 1938 with a BE engine. When the C came out, the B had a CE engine just like the C. There was also  gas engine at 5.75:1 comp ratio and a distillate at 4.75:1 so there would be another difference in HP.Confused
Edited by CTuckerNWIL - 01 Mar 2012 at 8:29pm
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:36pm
 OK what else?
I believe the fenders on a C have ribs unlike the B which are smooth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protrucker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:38pm
I was comparing the B to the C with the gasoline engine. I don't know the difference between the BE & CE engines, but the data listed the same bore, stroke & compression ratios for the B & the C with gasoline engine.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:44pm
Terry Dean's book says 23.30 on PTO for the C and 22.25 for the B on PTO. That is with the CE motor (1943-1957).
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:52pm
Well the 12.97 HP was from a test in 1938 (BE 116 cuin)before the CE (125cuin) engine came out. The C test was in 1940 with a CE gas (18.4hp)engine. I guess some details get lost in too much information. The same CE on distillate had less power(15.sompin). I don't know if there were different comp ratios for the BE engine. Too many numbers to look throughSmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:44pm
O
So essentially the b will not perform as well under the same load as the c with all the same motor because of slightly different gearing with the exact same ground speed? How does that work? I also put taller tires off of my c onto my b is this gonna hurt my ability to pull
R.W View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:47pm
I can't tell you about the gearing, but the taller tires will make you go faster than the stock size for your B.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:54pm
I would love to have power numbers for the BE gas engine. You're right; I'm sure it's higher than the 12.97 drawbar horsepower that the distillate version was tested at. I always figured the higher compression gas motor was around 15 hp or so but I don't have anything to back that up. Just a guess. It should at least be between 12.97 and 18.4!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 10:40pm
So let's say theoretically if I would put my shorter tires on my c it would slow me down but possibly give me more ability in pull with same pto speed? Does this sound feasible?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:33am
if I remember right the ground speed on the C is 1/2 mph slower than a B (at least in first)
Correct, the fenders are different. Makes sense that the shroud is different with the narrow front. How about  the steering box?
Charlie
Foolster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foolster Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 8:03am
I have a B I am rebuilding. Once that is through then I have a C rear end that I am going to put a four speed truck transmission and a Yanmar three cylinder diesel ahead of. From everything I have read the B and C were same tractor except for the early Bs with the smaller engine. The CA was really different with a four speed transmission. However, I think all the major castings have the same bolt patterns so you are able to make a working tractor from parts of any of the three models.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 9:14am
After 70 some years you will not find much difference between the (average) BE and CE engines.  You have to pull the head and use a ruller to tell the difference.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 1:17pm
Below is a link to a good article on the B/C/CA tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 1:34pm
It might have changed things some if the Snap Couple hitch had come out in 1950 as stated, but it didn't come out till 1953. Pretty good article though.
Edited by CTuckerNWIL - 03 Mar 2012 at 1:44pm
