AC 160 Steering Seals/Parts |
dlow8
Topic: AC 160 Steering Seals/PartsPosted: 01 Mar 2012 at 3:38pm |
Hi guys, I have a quick question. I have an AC 160 that I need some steering parts. The Power steering pump started leaking a while back. I took it off and noticed that it leaking around the front shaft (right before the pully) I assume this is a seal leak, but I'm unsure of what kind/size/type and/or where to order the seals. Can you guys point me in the right direction. I am also in need of the cap that goes on top of the Power steering Reservoir. Anyhelp will be appreciated. Thanks.
donais
Joined: 29 Dec 2011 Location: Ramona Ca Points: 160 |
Posted: 01 Mar 2012 at 3:58pm |
Go to agcopartsbook.com look up your model i thint under agco -allis that is where i found mine
dlow8
Posted: 16 Mar 2012 at 12:32am |
Thank you. I will check now
