cylinder ram disassembly
doctorcorey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Topic: cylinder ram disassembly
    Posted: 01 Mar 2012 at 3:10pm
   Can these large lift rams ( HD7 HD11, etc. ) be disassembled by humans with common large tools, or do I need to pay (shudder) someone to do it. My book states torque on packing nut to be 1200 ft lb. That likely means it'll take 3000 to loosen it after 20 years of rust and other electrolysis action. this ram has a worn bushing in the head end that let's the ram shaft "wobble". Any advice on this bushing and it's replaceability? Should I look for a replacement cylinder? WinkPaper or plastic? Marianne or Ginger? Boxers or briefs?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 4:38pm
You should be able to do it yourself. Might just take large wrench or tool and long pipe to get that torque.
 Bushing may be out there in used or even new , or can have one made. I had a bad piston on one cylinder on my 715B dipper and it was cast iron , replaced it with one made from aluminum and works fine. Cost was a lot lower than finding and machining a chunk of cast.
 Also it might be possible to have the piece your needing machined and sleeved to be brought back into spec.
 Also might get a quote from some shop to do the work of disassemble if you do have a problem.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 4:57pm
paper, maryann and briefs.Smile anyway, i agree with coke, do it yourself and even if you have to have a bushing made, it will be alot cheaper than having someone rebuild it. good luck with the long pipe for torque.
Post Options Post Options   Thanks (0) Thanks(0)   Quote doctorcorey Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:02pm
  well I'll give it a try. There's a shop in southeast missouri that says he can match any packings. Just send it to him and it's a done deal, he says. I'll ask him about the bushing. I've got most sockets in 1" drive up to 2" diameter. Thanks for the advice. Corey
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:18pm
you could also cut a piece of plate to fit the nut and make a wrench if you dont have something big enough.  then smack with a sledge.  i picked up a piece of old cutting bit from work to make the sprocket nut wrench for my hd16.  the nut was 7 inches flat to flat across.. and torque is 4500-5000 ft lbs.  service manual says to smack wrench with sledge hammer to break nut loose.
Edited by CAL(KS) - 01 Mar 2012 at 9:18pm
This page was generated in 0.124 seconds.
