XT III Air intake |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Topic: XT III Air intakePosted: 29 Feb 2012 at 8:18am |
piping question. Is there any sense in insulating the intake pipe from the front filter back to the turbine to keep any heat away from warming the piped air or would this issue be negligable? Also what kind/ brand of insulation have y'all used in that cradle/pocket where the air intake tube passes very near the top corner of the radiator? Thanks, Dana
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 29 Feb 2012 at 9:47am |
I would say no, probably 98% of the heat that goes into the intake, is post turbo, where it is pressurized. It may help a tiny tiny bit, but the hassle of messing with insulation is probably not worth it. Unless you plan to pull this tractor, and run it on exotic fuels, I don't think you would ever see a difference. The only time I have ever seen the intake insulated anywhere is in the pits at the pulls.
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
captaindana
Posted: 29 Feb 2012 at 2:10pm |
OB I was thinking probably around the 98% also. But it's fun to hear others thoughts instead of pondering alone. Thanks!
