Mag help
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Mag help
    Posted: 27 Feb 2012 at 10:00pm
I need a little advise on the magneto on my M.  I have spark for number 1 and 4 but not for 2 or 3.  I took the cover off, cleaned it up, put it back and still nothing.  I forgot to write down the number on the mag, but I will get it tomorrow.
  Thanks,
  Joe
Life is simpler when you plow around the stump.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 5:07am
most likely cap or wires. possibly plugs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 6:04am
Probably an H4 Mag. That problem could be as simple as a bad plug or two. Do a continuity test on the wires and make sure the wires are okay. Hairline crack across the end cap from opposite terminals would cause a misfire on two cylinders also. Might need a magnafing glass to find the crack in the cap unless the tracking is evedent. Moisture under the cap can also cause that problem. HTH
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 3:05pm
The mag is an American Bosch MRF 4 A 322.  Can parts still be found for these?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 3:20pm
http://www.magnetoparts.com/cat_index.htm
