WD Carb
AC Nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Topic: WD Carb
    Posted: 27 Feb 2012 at 8:44pm
Where would I find a carb kit for an older WD? I went to a local fleet store and bought what I thought was a carb rebuild kit as marked "WD". Appears gasket doesn't fit and some parts aren't the same. Is there a serial number stamped on the carb somewhere?
Thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:49pm
a MS carb with have a circular tag held by a rivet with numbers....  TSX---
not sure how it is on a zenith but it will have numbers also
somone can probably tell you what a WD carb # should be but i dont know offhand
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:08pm
Here is the tag on a Zenith 9707
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:26pm
Allis used a Zenith or a Marvel -Schebler on a WD. You have to know which one you have before you can get parts. They usually have their name on the carb. Bob
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:28pm
We carry the kits.  Give me a call tomorrow and we can help you identify it.
JimD
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 6:15am
The WD used both the Zenith small bore or the Marvel Schebler small bore carbs. You'll find the tag riveted to the fuel bowl on the Zeniths in most cases as in Stu's picture. The tags (if legible) will show the AC P/N on the outside, and the Zenith number on the inside around the rivet. On the M/S carbs, the tag is usually riveted to the side of the fuel bowl opposite of the fuel inlet. As Cal mentioned, the Marvel numbers start off with TSX-XXX and three digits afterward. The TSX-154 or 159 were popular M/S carbs for the WC applications. Large bore Marvels usually have their ID tags under the mounting flange. We offer kits, parts, and rebuilding services if interested...  HTH
Steve@B&B
