Swaying trail plow
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: Swaying trail plow
    Posted: 27 Feb 2012 at 1:29pm
I have a Oliver trail plow that I use with my B to do gardens with. When transporting it I can only go in slow second as if I go faster it starts to sway back and forth pretty violent.
Any ideas on what would cause this?
Charlie
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 1:37pm
   Does the tail wheel have a transport lock ?
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:05pm
This one is missing (Well it looks like it never had one) the tail wheel.
Is that the reason? I'll rig up my own tail wheel if needed.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:31pm
   Okay, does the back lift when you lift the plow ? Picture of the plow ?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:36pm
Slop in the hitching. I have had two old Oliver plows and they are the worst I have ever had hitched to a tractor for hitch slop due to the way the hitch is made and in honesty they were both darned near completly worn  out.  Look back while going fast enough to make it sway and see what is moving around and repair it.
Edited by Butch(OH) - 27 Feb 2012 at 3:39pm
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 6:12pm
I have a disk that likes to wobble when I pull it behind my truck. I take a ratchet strap and hook it from the tongue of the disk to one corner at the gangs and cinch it down.  The side load takes most of the slop out of the hitch and it pulls like a dream up to about 50km/h.  Can you do that with your plow?
I hate going slow on the road too Wink
Edited by Roddo - 27 Feb 2012 at 6:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:08pm
that's an idea. I'll give it a whirl
Charlie
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:22pm
I have a two botton #8 IHC on rubber, gravel and some blacktop make it wander and jerk back and forth and you have to back the WC down to half throttle to make it stop. On other roads I can hammer it wide open to the full 12 or 13 mph. I think it's because I replaced the rotten back tire with a regular trailer tire instead of the original angled type so it rides on the edge of one side.
AGCO My Allis Gleaner Company
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 10:22am
Two more things.  On many plows, the two wheels are not across from each other.  This will make it sway.  Also as with any trailer, if the weight behind the wheels is greater than the weight ahead of the wheels, you will never get it to stop swaying.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:26am
Must be an oliver thing, because the oliver disc we have likes to do the same thing.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 11:42am
The best solution would be a mounted plow.  In addition to totally eliminating any transport problems, you can get into and plow tighter garden areas.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 1:01pm
True on the mounted plow. I've looked for 2 years for a plow for my B and have yet to find one within reason and distance. Most are missing items that I need to mount it up, I can find the plow and beam but the remaining items are gone.
Charlie
M Diesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M Diesel Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 1:33pm
The thing with trailing plows is to not get them up high when towing. Keeping them down low while driving really helps the hitch geometry.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 1:43pm
Dad bought new Oliver plows when I was a kid and our instructions were, (keep it out of road gear when going down the road to the field) They would sway some in fith gear if you went wide open. I have never pulled my old well worn Oliver plow down the road.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:02pm
I probably have what you need to mount a B plow, or at least a large part of it.....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:33pm
Cool! But you are 5 hours away!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 2:36pm
Well this one is well worn for sure. I think the missing (Optional?) transport wheel plays a big issue. I am going to see if I can make one.
Right now the rear plow almost skims the road when traveling.
Charlie
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 5:46pm
Charlie:
I'm sure we can scare up enough parts to put a pick up plow on your B.  I know I have a spare depth lever, and I might have a spare beam & moldboard assembly.  The drawbar and brackets might be tough, but I'm sure that something could be found reasonably close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2012 at 8:41pm
Thanks Brett! I have the Depth lever, I thought you just reversed the drawbar?
I've watched CL and Claz for a long time and strike out. Garden plowing is paying for my toys right now.
Charlie
