How much can my "B" pull?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: How much can my "B" pull?
    Posted: 27 Feb 2012 at 10:04am
Do you think I could pull 2-12 or 2-14 plow, like the ones 8n's and 9n's fords pull? It has the later CE motor and will spin the tires in 3rd with a snap of the throttle, the only thing I'm thinking will be a problem is being such a light tractor?
What do you guys think?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:12am
Level field?  What type of soil?  The 8N Ford used a mounted plow.  That makes a difference.  I would say you could pull 2-12s under most conditions.  2-14s?  That all depends.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:38am
I bet with the optional snap-coupler and mounted plows plus some weight, you could pull circles around an 8N.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:49am
   R.W, can I ask why you are asking this question ? If I remember right this is going to be your cultivating tractor.
http://www.rumelyallis.com
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:58am
In our area, if you weigh it down to about 4000 and use a mounted plow you can do it.
Horsepower in not much different.  Assuming your B is in top shape.  IMO
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:02am
Mostly sandy ground and not any hills, yes it would be a 3 point plow.
Rfdeere, that was my original plan to just cultivate but because this tractor has a 3 point hitch it is not a big deal to switch between implements. Not to worry it will still be used to cultivate!Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:18am
   Then just use a one bottom. Why are you worried about what those Dorf's are doing ?
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:20am
Your not that far away from me. In sand, you should be able to pull a Ford style 2x12 0r 2x14 plow. If anything, you may need to add some frame weights if the front feels light. You don't have to plow as deep as China!!!!
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:38am
I was just referring to that style of plow.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 11:40am
Front end weight won't be a problem, it just has no weight on the rear tires it doesn't even have fluid in them.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 1:26pm
3 point, I bet only a 1 point. You will have no depth control over it only you use some form of mechanical means (Like a tire)
I pull a Oliver 2 point trail plow with my B, clay will make it snort, otherwise it does fine. I'm at 2500 lbs with wheel weights. I only do gardens, no field plowing.
Charlie
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 2:00pm
2-14s will work it. I have a 2-14 trip plow and the c has problems. Clay here though. Decent tires?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 2:17pm
What do you mean 1 point?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 2:18pm
Tires are about 80%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 2:26pm
I think he is commenting about the lack of draft control.
countryguy828 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote countryguy828 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 2:44pm
I have the cross 3pt on my B. I tried 2 different 2 bottom Ford plows. One would only plow about 3 inches the other dug in too deep and just made the tractor do wheelies uncontrollably. The problem I see with the cross and worksaver 3 pt conversions is that the draft point is higher than the axle center. If the draft point where lower I think it would be fine.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:04pm
Sorry, but yes. Lack of draft control with that basic 3 point will not perform very good.
Get a trail (trip) plow or a mounted 1 bottom and go at it.
Charlie
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:52pm
So the best idea if I want to go with the 3 point is get a one bottom plow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:57pm
You will still have the same depth control issue but I think if it had a side wheel that controls the depth you should be fine. I don't think a standard Tractor Supply 1 Bottom plow would work.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 3:59pm
Also if I remember right your 3 point has no way to adjust 1 arm up/down to compensate for the wheel drop into the furrow?
Charlie
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 4:16pm
Your best bet is to go with a plow made for the B if you want a mounted plow. If you use a three point you still have to level the frame side to side even with a one bottom plow if you want to do a good job. You also do need the draft control to plow without playing with the lift with one hand all the time the plow is in the ground. I have a plow for the B out here at the house, one on the dock at the plant and at least one in the scrap yard at the plant. I probly will never mount any of them and use a pull type plow any time I want to plow with any of the B's.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 4:24pm
I also think that using a 3 pt. plow on a B would be a pain. Since you probably want to leave the 3 pt. on the tractor for other implements, your best (easiest) bet might be to get a trailer plow like Dick L mentioned. Taking the 3 pt. hitch off and putting it back on when you're done to mount a B plow might get old pretty quickly.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 4:56pm
Both arms are adjustable.
Maybe I just need to sell the 3 point and get the original implements? That sounds like the best idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:07pm
Borrow a Plow and see what happens
Charlie
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:43pm
I know someone that has one and I'm sure he will let us barrow it.
