CA hydraulics |
Post Reply ![]() |
Kforeal ![]() Bronze Level ![]() ![]() Joined: 29 Jan 2012 Location: New York Points: 16 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Feb 2012 at 6:27am |
Did the CA come with one or two hydraulic rams for the rear? Mine has one but I'm seeing pics with two.
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
They came with two rams, one on each side.
Thanks & God Bless
Dennis |
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
You have to have two rams when you use, for example, the cultivator. One ram lifts the rear, and the other lifts the front. Then, you adjust the pump so that the front lifts and lowers first as you operate the pump control.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Yeep two cylinders came standard. Perhaps somewhere along the line your CA had a woods mower under it. The mower needs only 1 cylinder to raise/lower it and the other cylinder may have been removed.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Yes Greg that's exactly it. Im going to have to locate another ram as I don't plan on using the mower so much. I'd like to get the 3 point set up. Light duty. Thanks fellas
Anyone have pics of how the two rams are connected and plumbed?
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
the junction block is under the platform just to the left of the lower shock mount. You cant see it with the platform on. the two ram hoses come off the sides and the remote hookup comes up through the hole in the platform. It will still lift a three point with only one ram installed. with both rams installed it will lift way more than the front end will hold down. there is a good drawing in the parts manual. go to agcoparts and look under heritage line.
Post Reply ![]() |
