D17 Series 1 Engine Rev'd too high
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series 1 Engine Rev'd too high
    Posted: 27 Feb 2012 at 5:46am
1958 D17 gas:
What could cause my engine to rev extremely high?  I was pulling it out of the barn yesterday at about half throttle, and it suddenly revd VERY high, don't know how high, because I don't have a tach, and I immediately shoved the throttle back to idle.
The oil pressure gauge pegged, and now I hear a whining noise that wans't there before.  I am hoping that noise is the generator bearings and not the engine.
Is there supposed to be a return spring on the carb?  Mine does not have one.
I had this engine completely overhauled in late 2010, and it has 95 hours on it since the overhaul.
Thanks,
Roscoe
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 5:54am
sounds like its something in the gov. id check all linkages and go from there. hth. allis6080
6060 s\n 5016
1947 JD B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 6:23am
I agree. Sounds like it could be linkage hanging up or a possible govenor problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:01am
Well, crap.  So much for wishing it is something simple, like a missing throttle plate spring.
thanks for the replies.   I am still hoping that I didn't trash the engine...
- Roscoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:12am
Sounds like the gov. weights broke and the noise you hear is timeing gears where weights went through them.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:15am
Through them?!!  That can't be good, right?
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 7:44am
i hae gov. weights and gear from series one.all me 5635420673
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:21am
Mine took teeth off all the gears when my weights came apart and wouldn't run at all. Pull the distributor so you can see what's going on. Cross your fingers. You might get off easier than I did.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 4:18pm
OuchDrain the engine oil to see if theres any metal chunks that comes out.
