Probably nuts, but Oh Well
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Probably nuts, but Oh Well
    Posted: 26 Feb 2012 at 7:00pm
Well as I noted in Had to Pass, I did manage to get hold of the seller and this week will get him his cash for the old HD7G pile of iron, next step is to get a hauler to pick it up and set it off on the old farm place to start digging into what ails it.  Have contacted a hauler local to us, got a reasonable price from him but not sure as to when he can pick it up yet.
I may be nuts at my age for tearing into this big a project but hey, I gotta do sumpthin to stay busy!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 10:43pm
Look at tit this way will keep you off the streets and out of the bar , well at least until something comes up that drives you to drink. And by then it might have cost you enough you cant afford over a 1/2 glass of barley pop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:33pm
I will have clearer photos come Friday, I got the hauler for Thursday my day off to go get it, hopefully it won't be worse than a worst fear!!
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 9:49pm
Originally posted by Coke-in-MN Coke-in-MN wrote:
Look at tit this way...
I'm assuming this is a typographical error...
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 10:37pm
this , my fingers seem to either miss a few letters or put to many in, .. Then my mind might be off track also .. or on track but on wrong subject.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:08pm
I got it home.  The turbo is not bad it is  spinning up fine, air cleaner has not been out for awhile!!  Steering issue, both brakes have to be on the floor to get any function, I will adjust first then see where it is.
Runs, starts, drives good, has hydraulic leaks, has not been serviced in a long long long time so that will be one of the first processes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:13pm
Track rails look great, sprockets too, guy that hauled it said they looked almost new.  Master pins is a hodge podge who knows where it cam from so will order correct ones.  Floor board pans are just removed I did get them, everything under covers is a pig pen mess!
Edited by DMiller - 01 Mar 2012 at 6:13pm
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 6:32pm
hi DMiller
that doesn,t look too bad at all. Apart from where some caveman  who was steering it has somehow bent the top of the bucket ! ! People like that need to be put back on handshovel for awhile to learn to appreciate machinery. 4 in 1 bucket too; makes them twice the machine. Adjust your brakes up and hope your steering issues will be solved; change fluids clean screens and new filters will help too.
keeps you occupied; remember better to wear out.
than rust out !  !
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 8:29pm
Serial tag is long gone, got into service manuals and found location to stamped number spots, believe it will be from the 23xxx number up from air cleaner/throttle and brake linkages/etc that are serial specific.  I ordered and have new service manuals, they are repro but are fine, I got old manual from the previous owner but it is in the same condition as bucket back stop.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2012 at 9:10pm
well your pictures make it look a lot better than what i was imagining from your description.  really those sprockets dont look too worn and the rails dont seem to be pounded flat either.   Looks to me like you made a nice save.  just needs a lot of TLC.
good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:30am
Got a shocker from Minnpar as I placed a order this morning; supplier for some of the pieces on these old dogs is shutting down the lines and ending replacement components, I could not get replacement master pins from them as they do not know when or IF they will ever be available again.  Looks like back to old fashioned machining work again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:37am
I am going to cut away the spill lip on that Ulrich bucket, plan to manufacture a brush cage from either 3/8 or 1/2 x 2 or 3" strapping to replace it, won't be working dirt that heavily to need it as a spill lip.
Filters are also a little scarce, found a few local but ended up purchasing most from Application Associates out of NJ, a Baldwin supplier.
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 11:52am
thats a fine looking machine I havent seen one personaly in over 20 years I have wanted a 7g since I was 8 years old  my dad the the hd7g and then a 7gb . there was a guy that had one arm that had a hd7g he bought new the same time my dad bought his 6g new in around 1968
This page was generated in 4.740 seconds.
