Cleaning questions
kschab92 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kschab92 Quote  Post ReplyReply Direct Link To This Post Topic: Cleaning questions
    Posted: 26 Feb 2012 at 11:01am
I pulled the axle out of my wc last night and it is just covered with sludge on the inside. What is a good way to clean this out? My thought was to drain the differential and flush some mineral spirits through the ends of the axle housing a few times. Any other ideas?
Also when I prepare to paint, there is quite a bit of grease that wont come off with the pressure washer. If I scrub what I can off and sandblast, will the sand take off the oil or will it push it into the metal?
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 11:54am
I use kerosene.....mine was sludged when I drained it too. When you prep for paint, wash with either oven cleaner, or comet....neither will affect paint. I always wipe with laquar thinner too.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2012 at 12:08pm
Electrolysis works if you have a little time. It will remove old paint and rust also.
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
Some say,"I don't have a container big enough" Just dig a hole in the ground or build a wooden box and line with plastic. Lots of old lawn mower blades help:)
