WD pto leak
Branden(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Branden(IL) Quote  Post ReplyReply Direct Link To This Post Topic: WD pto leak
    Posted: 03 Dec 2009 at 6:59pm
The pto housing on my WD has developed a leak.  When the fluid is warmed up there is a steady drip.  How bad of a job is it to fix?  Is it just a seal?  The other dilema is that I have a mounted corn picker on the WD, so it will be a challange to get at the pto housing.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:04pm
I replaced the one on my WD a couple years ago.  Could not find the AC extra large seal, so just install two automotive lip type seals in tandem.  The PTO is used a lot (bush hogging) and it has not leaked since installing the seals.  The hardest part was getting the PTO shaft separated from the PTO housing. Just remove the bolt and wedge a large chisel or wedge between them.
Dennis IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:06pm
Brandon, most likely just the seal. It is a donut shaped seal that is no problem to get from AGCO just be careful you tap it easy and even when you put the new one in.  Dennis.   One more thing the new ones have a rubber seal and the old (original had felt) so don't worrie when you see the rubber instead of the felt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:16pm
Branden, after reading your post again I'm wondering if it's leaking from the housing where it connects to the tractor or is it leaking around the Pto shaft where it goes into the housing????
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Branden(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:20pm
it appears that the leak is coming from the pto shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:46pm
Ok that's what I thought Branden. The above is accurate then. Take the two bolts that hold the rear of the shaft in place out (DON'T let it drop have somebody hold it or rest it on something so it remains straight) next, take bolt out that connects shaft to stub shaft that protrudes from the housing, then take out the (if I remember right) three bolts from cover (they are in a triangle configuration) then tap old seal out. Don't forget to drain oil first LOL! then being careful, tap new seal in with a block of wood so it goes in even. the part number is #70224779-2
