8070 FWA loader
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: 8070 FWA loader
    Posted: 25 Feb 2012 at 3:52pm
Can buy a good used Allied loader that will fit my 8070FWA ps.Was thinking about putting it on to load hay with but concerned it may be to heavy and bulky.Anyone on here have a loader on ther 8070? If so how do you like it?
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 4:58pm
I have an 895 allied on my 8030 fwa,was not balanced well and front heavy untill i moved the  axle forward 14" now i love it!!
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 5:40pm
Adam   It's a 895 loader that I was looking at.It was mounted on a case tractor so I would have to have the brackets modified.If I moved the loader farther back toward the rear you think it would solve the problem without moving the front axle forward?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 8:33pm
I had the 8000 series brackets and they pretty much put the loader as far back as it will go....everything worked ok just had quite a bit of "hopping" when roading between farms,also lifting capacity is much better w/axle forward as it dosen't leverage weight off the rear as easy, If your just loading hay that won't be a problem though....as far as the loader its built very well and though it dosen't remove as quickly as other brands I would put it against anything for stoutness!!! (and the price is way better than westendorf) pictures of my setup a few pages back...search "loading junk" also had a thread 'bout the axle mod. search "8000 front axle"
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 8:19pm
Thanks for the inf Adam.I think I'll buy the loader but will probably not put it on the 8070 for the time being.Been waiting on a 6080 FWA in good condition but there not many around in my part of the country.
