Ian's D14 project and questions.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Topic: Ian's D14 project and questions.
    Posted: 24 Feb 2012 at 9:03pm
2 days after i brought it home.
So as she sits now.  I bought it last august. Got it home.  Parked it in the barn. played with it the next day for about 20 minutes, checked the oil...white.  So pulled the hood and valvecover, full of water.  Not sure if it was because the grommets around the bolts were gone and the hood was smashed into a bucket shape directing all the rain into the motor or its got bad freeze/plugs or head gasket.  I bought a gasket kit, got ready to tear it down, and my truck blew up.  Priorities...
So 5 months later, the truck is fixed, a couple other projects are getting finished so I'm starting to tinker with the allis again.  I've beaten most of the dents out of the grill and screen, however the hood panels may be too far gone for my sheetmetal repair skills...which are somewhat limited.  So my question there is, are d15 hood panels the same as a d14? I'm having trouble even finding D14 metal for sale.
It does have 14.9x24 tires on, one decent and one gone , so I'll need some new rubber sometime soon, there's car tires on the front that I dont know how they hold air, but they do.
Mechanically it ran good and drove ok in 1,2, and 3.  I never tried 4th.  The PD worked but it never went into Neutral.  Clutch felt good and brakes worked. The first of my two biggest concerns I have are that the hydraulics didn't work at all, I've heard that the lobes on the shaft have been known to wipe off and are very pricey.  I'm crossing my fingers It's something else.  The second concern is that while it's sat, ALL, it seems of the transmission/PD/PTO fluid has leaked out.  I'm not sure where it's coming from.  The seal around the PTO shaft is leaking but the bell for the Snap coupler is covered as well.  I have not investigated much yet at all either of these problems.  Only looking for suggestions on where to start really.  I'm an auto mechanic, but am new to working on big tractors, past normal maintenance and basic operation so any help or guidance is appriciated.  The hydraulic system is the real mystery to me, as I don't have much experience at all in that, so wish me luck.
Plan to use it mainly as a mower and working tractor around the property, light dirt grading and maybe garden plowing.  Been fun tinkering so far, plus the neighbors all have John Deere CUTs so kinda looking forward to parading around on a 50 year old bright orange Allis :)  I'll post some more pictures and ask more questions I'm sure as I go along, Loving the site.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
1974 Cub 154 Lo-Boy (SOLD)
Hauler: 1998 Dodge Ram2500 Cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:53pm
I think the 15 is wider???
If your hydraulic fluid leaks out the bottom, the lift arms won't.:)  If fluid is leaking out you'll need to clean it up and locate the leak.
If it was mine, I would look around for some original or replacement PAW's before I spent a lot of money on rear tires. Problem is new rims and tires might cost more than you paid for the tractor but you would have adjustable width in the back again.
Edited by CTuckerNWIL - 24 Feb 2012 at 9:54pm
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:22pm
It's actually gear oil that's leaking, I believe.  I assumed it was the transmission fluid, is it the same? I have a service manual for it, and have been reading but i guess I'm having trouble seeing exactly how all the different systems interact.  The hydraulics mainly.  I know the pump is behind the bottom cover of the torque tube. and the control valve is in there as well.  I assumed it had a seperate resorvoir for the hydraulics from everything else.  Unfortunately I've only become familiar with the sheet metal so far.  I have yet to dive into anything mechanical past the engine.
I've been on the lookout for a set of PAWs either 26 or 28.  I would like to stick with the wider tires seeing as it will see mostly yard duty, and that seems to be the hard/expensive part.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 9:08am
The rear rock shaft is operated by an internal hydraulic cylinder. If that cylinder leaks or more frequently, the hose that supplies it leaks, the hydraulic fluid will over-fill the differential housing. These days the fluid could be the same(hytran oil) but if the rear is over-full the pump can be starved, disabling the hydraulic system.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 9:40am
Fill it back up and see if the hydraulics work then check for leaks and as Charlie said check all the fluid levels again to see if one goes down and the other goes up.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 10:29am
Yes, That happened to my D-15, the over flow of oil in the rear end ran out the top by the shifter. If thats the case its not a terrible hard fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 11:37am
WD or WD45 or D17/D15 rims tires will all interchange for rear tires.   My D15 came with 28" rims and I later found the correct D14/D15 rims/tires and sold the other ones.   I believe the D15 sheet metal is wider then the D14 sheet metal.   Watch ebay, from time to time someone will part out a d14.     I myself would deal with all the mechanical issues first and then worry about sheetmetal/tires.   Somewhere along the way you may or may not find something terminal and then at least you didn't spend money on tires etc before you got all the major stuff fixed.
My D15 rear cylinder was leaking too, and I replaced the seals and the hose this summer.   Not too hard of a job.   The cylinder can leak fluid, and the hose that goes to the cylinder can start to leak also.   Once you're in there it's best to replace both.   LIke everyone else said, watch the levels in the hydraulic compartment and the rear end, and see if the rearend fills up and the hydraulic compartment loses oil.   Then you know it's in the ram and you can't tear that part down.
Good luck.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 12:09pm
Thank you all for the replies.  I do intend to restore it to working order, I doubt I could fine anything bad enough that I wouldn't fix it at this point.  I'm not painting it until it's fully functional though.  Tires aren't high on the priority list because the ones on it hold air at least.  Only doing the sheetmetal at the moment because it was convenient and my big barn where the tools are is full of crap at the moment.  The allis itself is in the small barn you see in the picture, I rolled it over there after I tore all the sheetmetal off to make room for my truck.  Once I can get it back over by the tools I'll get into it mechanically. Hopefully later this week.
I do know I can lift the lift arms to the upright position and they'll stay a few seconds and then fall slowly to the lowered position.  I assume that would mean there is definately a leak somewhere.  Do you have to split it at all to replace the line?  I do have a spare ram for another piece of equipment that I could hook to the remote to see if the pump is still working.  The remote and lifting ram are independent correct?  Of course I have to get the motor back together before I can do any of that. Hopefully tomorrow.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 12:26pm
The rear remote is plumbed parallel with the rear lift cylinder, the hydraulics will lift the easiest one 1st then the other. You would need to disconnect the supply line to the rear lift cylinder (before the rear remote) and attach the supply line to your test cylinder to determine if the pump functions. To get at the hyd cyl that operates the rear lift arm you need to remove the rear pumpkin; the cylinder and hos to it are inside. Not too difficult if you have a cherry picker hoist to pick the pumpkin.
AGCO has online  parts manuals available to view the parts/assembly and/or obtain the AGCO part numbers. Link is below; sign in as a guest and lookup your tractor by typing D14 in the box and selecting "AGCO Allis" in the drop down box.
These tractors are basic mechanical machine; no computers, no fancy vaccum, and basic electrical and hydraulic systems. Good luck and feel free to ask advice here.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 2:10pm
greg that site was very helpful, so basically after the feed from the pump goes through all the control valving it goes externally to the remote and then t's off to the lift cylinder?
I have a basic understanding of hydraulics and have stared at the factory manual many times I just was having a hard time understanding the flow I guess.  I figured once i went and got everything apart and started messing with it I'd have a better understanding.  I thought though when there was discussion of a line inside that it was a seperate one from the pump to the cylinder that was internal.  Think I got it now.  Hopefully anyways :)  Maybe I'll get to mess with it tomorrow.
My other question for now, does the power director share fluid with the hydraulic pump?
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
allis d14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2012 at 2:12pm
hello everybody
i have a question about a d14 i was reading the posts on the hose leaking to the ram and my question is. is the line that feeds the ram internal to the tractor or is it external? the reason why i ask is i have to split my tractor to fix the pto drive and i know the pump is up front and the ram is in the middle towards the back so i was wondering if there is anything i should be carefull about when i split the tractor i will be splitting at the power director? and one other quick question when i split at the power director does that just slide off a spine shaft or will i have to disconnect anything inside before i side it apart. the manual is not to clear
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2012 at 12:06am
Allis, answered both our questions today.  The line that feeds the ram is internal but only from the block that is the remote, to the ram.  the remote is actually a "T" fitting.  you can't see the hose until you unbolt it from the lift arm housing.
I do believe my ram is leaking, the hose looks ok but I'm going to have the ram rebuilt at a local hydraulic place and I think I'll have them make me a new hose as well just for peace of mind.
Have to pick up some freeze plugs tomorrow and hopefully we'll get her running again this week.  Supposed to be nice out for a couple days, so would be wonderful to make some more progress.
I did find a whole explaination of how the hydraulic system works in the back of the service manual.  I never saw that before today.
 Thanks again all for the help!
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:27pm
Got the engine torn down to find out my coolant/oil mixture problem.  The freeze plugs in the head seem to be intact, the two outer most ones look newer though.  I'm going to replace all of them in any case.  What type are better, steel or brass? I would think brass would corrode less easily.  My other concern is that the head gasket doesn't seem to show signs of leaking which leaves the liners.  How often do the liner orings go bad?  and can you get them without the liner itself?  I'm leaning towards buying an entire overhaul kit at this point.  I found 3 cracked rocker towers, held together with hose clamps from a previous owner.  I need a water pump for sure.
I do have a question about the overhaul kits.  They mostly are listed as overbore 3 and 9/16" and for the d14 as well as the d15.   with this and a governor spring make this essentially a d15 motor?
Edited by Ian - 12 Mar 2012 at 10:29pm
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 2:47pm
Liner o-rings are a common thing to go bad. You can buy just the o-rings, not sure on cost but your best bet would be from one of the vendor's on the site. I have one of the overhaul kits in my D14, got it from OKTractor.com Jim is a great guy to deal with. The rocker arm standoffs can get a little pricey. I ended up going through Norms Tractors to get CNC'd steel ones from him. Cost me $50 a standoff a few years ago. Great quality and no issues, won't crack either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 3:45pm
Also I use the brass freeze plugs.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:46pm
Jeff,
I was actually looking at OKTractors website last night.  Lot of useful stuff there.  I'll definately be giving them a call.
The rockers! I don't know how much more dense I can be sometimes.  I'm sure Norm's are great, but I have a mill at my disposal...and loads of mild steel blocks laying around.  It never even crossed my mind just to make my own.  I'll try that first and call Norms when I mess that up. :) Thanks for the idea!
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 8:50pm
I planned on making my own but I couldn't get access to a mill. If you do make your own make sure you put in the oil galley and hole for it. Good luck, if you have any questions I would be more than happy to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 9:26pm
hello ian
so to get the line off the ram i need to remove the lift arm housing? is the line metal or rubber? and do i need to disconnect the line before i split the tractor? i have to split my tractor at the power director because i need to get in there to see what happend to my shift mechanism for the pto. the service manual is so unclear. any help is greatly appriciated.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:09pm
Allis you do have to take the lift arm housing off.  You don't have to mess with it to split it further foward though, I don't believe.  I've never split mine so I'm not entirely sure.  Hopefully someone else can chime in.  The line is rubber.  and if you unbolt the remote ontop of the housing and pull it up you'll see where it goes into the bottom of that.  you can't get to the ram side with the housing on though.  hope this helps!
Jeff I did see the oil notch thankfully, but is there a seperate feed hole I missed?  I just looked breifly tonight but haven't started making anything yet. Im sure it would be detrimental if it were omitted :)
Thanks for the help.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis d14 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:37pm
so what you are saying is the remote port on the back of the tractor is capped on one side and then goes gown into the housing to feed the ram? right. why doesnt the crappy service manual show this. i thought the line ran internal of tractor between the housing. so all i need to do is disconnect the line running up to the fitting under the seat and then i can sepeate the tractor.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 11:07pm
Allis yes, the external line that runs from under the gas tank to the remote block will need to come off to split it. I had the same thoughts when I started into this.  I thought the external line fed only the remote hookup, and there was an internal line.  But others helped steer me here.  the service manual does have it in there but its hard to see.  once you know what you're looking at you'll see it.  That's how it happened for me anyways.  Help from others on here and once I got into it and took it apart it all became clear lol.  Well as clear as it can be for me I guess. :)
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 7:13am
Someone, some time ago, posted pictures of his D-14 split apart for the lift cylinder repair.great pictures...shows what's involved.
maybe search for 'd14 lift ' ???
You could come and 'practice' on my D-14 if you want.....lol...
I have to get the new ring gear on first, put the front of the D14 together THEN tackle the other end......
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 9:44am
Ian, now that I think about it, I think there is just the through hole for the stud and a horizontal oil notch, that notch is just a drain to drain the oil from the rocker arm shaft. Make sure you do have both ends of the shaft plugged, they used cork originally. The oil is supposed to drain from those notches to provide proper lubrication to the rocker arms. You then have a tube that goes from the head to the rocker arm shaft.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:32pm
Yup, the oiling system is quite...external on these.  I like the simplicity of it.   On that note, where do you even get the line to replace the external oil lines?  Mine aren't leaking, or don't appear to be, however they're bent and discombobulated.  I've tried to straighten them with not much success.
I haven't noticed the tube yet, whether it has the plugs intact or not.  There was a small amount of metal in the oil, so tommorrow I'm going to pull the pan and a main cap to see how horrible my bearings are.  I got a rough cut on the rocker towers but no holes drilled as of yet.  I'd like to be able to order parts by this weekend and get it back running next week.
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:20am
What you can do for the oil lines is just replace them with steel brake line. You may be able to replace them with stainless steel but am not sure if you would be able to flare it properly. If they look okay, I just clean them out and to a pressure test on them by plugging the end and putting a few pounds of air through em.
Edited by JeffMOnt - 15 Mar 2012 at 8:21am
This page was generated in 0.079 seconds.
