AC 200
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Big Al 485 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Topic: AC 200
    Posted: 23 Feb 2012 at 3:34pm
I am interested in an AC 200 and would like some opinions if possible as I was recently told to stay away from that model as it was nothing but trouble.
Does anybody have one that is not trying to sell it  want to offer any advice ?
Would 175 be a better fit as I already have a 185 which I am really impressed with other than the small rear tires. ( 18.4 x 28 ) .  it will be used mainly for making hay.
Thanks.
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 3:50pm
200 "nothing but trouble"?????  Who told you that?  A 190/200 is one of my favorite tractors.  Nice wide platform, consol control (with throttle in console). My opinion a very nice setup tractor.  The 200 is exensially an updated 190xt.  It has the later transmission (better), four pinion differential, and larger axles of the XT series III.  Some of the early 190's were not that great as they had transmission problems and diff. problems (I have an early one that has trans. problems.)  Very easy on fuel in my opinion.  A little cold natured in winter though, a block heater would help on mine.
Adam
Tony Elo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony Elo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 4:22pm
the 200 is a good tractor,it doesn't hurt to put a coolant filter on them with the additive in the filter,depending on what you want to do with the tractor it is reasonable on fuel,not the fastest on the road,but reliable.The biggest downfall with it is if you want live pto,you have to remember to use the lo and hi range lever, if you use the foot clutch which is the normal reaction,your pto implement stops with the foot clutch
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 4:24pm
   Big Al 485, you haven't been talking to Old Tanker on YT have you ?
http://www.rumelyallis.com
Racn911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Racn911 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 4:35pm
I've have nothing but good things to say about mine.
Adam Koch
Aviston Illinois
75-200 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75-200 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 5:49pm
My 200 is hard starting compared to other tractors.  The power director has been a source of trouble.  We have to repair the p/d for the second time after not enough hours on the first rebuild.  I have a 2-110 White which I find to be a more reliable tractor.  I ran 70 and 90 series Case tractors and had less trouble overall compared to the 200.  This was our first and only Allis.  They are rare in our area and I can only guess that the 200 was not A-C' s best effort.
A more recent post on this thread reminded me that I too had to replace the hydraulic pump at relatively low hours at a cost of $2200.  And I too have a heavy loader on mine which doesn't get abused yet I have replaced more wheel spindles than I can count (at $185 a pop for aftermarket spindles).
Edited by 75-200 - 23 Feb 2012 at 6:31pm
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 5:55pm
The only ones that I've heard being a problem the guys dualed them up with fluid in both inner and out wheels, and some wheel weights. Then turned the pumps up putting out over 150 hp. But any one using the 200 for what it was designed got along very well with.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 6:13pm
My experience with a 200 is very negitive , the transmissions are worse to gear jump out , the powerdirector controls give alot of bulls--t trouble ; brakes are terrible to keep working - Allis made a - cost reduction version of the 200 , i think they all were
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 6:23pm
I bought my 200 on Good Friday in 2003, had 5600 hrs. it has the manual pto, which is dependable, but I wish it had the hyd. I did spend the money on two good batteries, and it will start on the South pole. brakes still work fine. it now has over 7000 hrs on it so I have had the hyd pump and inj. pump rebuilt. but that is due to normal wear, at least I feel. the power director gate can be a pain, but you will know right away if the linkage needs adjusting if it wants to "slip" out of the gate. I have a big ole Dual loader on it, and it does everything I need it to. NO complaints. As stated, ya cant fill the duals with fluid and turn it up. prolly wont hold up.
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:18pm
Big Al all I can say is in 1973 my dad bought a 200 new and it was our big tractor and we did nothing but bull work dauls on rear and we put like 3400 trouble free hours and then dad traded it on a used 1977 7040 power shift.I really liked both tractors plus dad bought a new 7060 in 1976 it had the 20 speed liked It too!!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:23pm
I have a cost reduced 200 as well as a 190XT series III. The 200 has given no trouble at all, and it was not well cared for by previous owners. The transmissions are much inproved over the 190's.
Anybody can have a bad tractor of any make or model.
A lot of power director problems are due to linkage issues causing the valve to not be fully open. The clutch then slips. The Reduced cost 200's linkage is less likely to have this problem because it uses an overtravel lever and springs.
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 9:26pm
A 200 is the best of a very good, perhaps iconic tractor, the 190xt. They are a very handy tractor for many jobs, drawbar and pto. Many people abused them, but abuse a 4020 or 1206 and see how much money you put into it. For haying, and for the money overall, I dont think you can buy anything better, Trev.
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 10:21pm
Our 200 was one of our best, had over 5000 hrs when traded for the 7080.  Our first deisel.  Then the 7080 turned out to be our worst.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 11:12pm
I have a 1974 200 that I bought when it was 2 yrs.old. The hourmeter (not tach) quit working at 5000 hrs. even. I would guess it has around 9000 hrs. on it now. Yes,it has had an engine rebuild,clutch,brakes,inj.pump,turbo and a few other small things,but this is to be expected if you really use any tractor. The 200 was the last AC tractor made with the hand operated PD. Mine has the gated PD control and I know some people bad mouth this,BUT it is without any doubt the easiest to use PD control AC ever put on a tractor. The short lever with it's short throw and hand guide makes shifts so easy and smooth. Personaly,it looks to me like the 190's and early 200's with the taller "push down" lever would be very difficult to shift smoothly between ranges. Bought a new 185 in 1972 and that was the most awkward PD control. OH and don't forget,like the 190"s,the 200 is one of few AC's made with the throttle where it should be--on the right hand console. I can honestly say it has been a good tractor and after all these years,I still enjoy using it.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 11:22pm
How do you know if a 200 is a cost reduction or standard tractor?
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 6:47am
I spent many summers on a 200 raking and bailing hay.  Other than having to recharge the AC twice a year from a small hole in the system we never had any mechanical problems on a 4000 hour tractor.  We had more problems with the 7000, always something with the shifter cable and running hot.  But then Texas summers will find that weak spot on the cooling system.
1944 Allis C
1960 Allis D-17 LP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 7:20am
Thank you all very much for the advice. it sure is nice to have this forum to be able to talk with folks and get very valuable information.
I think  that if the right one comes along ( one that has not been abused )  I will give it a try.
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 8:50am
I love the 200's but you mentioned a 175 and mainly doing hay. I'd probably go with the 175 for hay. One thing is less fuel and the other would be your less likely to knock the people down on the haywagon with the manual PD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:09am
I do like the 175s too, but like the bigger tire size ( smoother ride ) and walk through platform of the 200 also.  I probably will go with whichever one is the cleanest tractor.
I am under the assumption the the power director is what I refer to as the PTO lever.
Is this correct ?  When you say that the 200 has a manual power director does that mean that you have to depress the clutch to engage the PTO ?  I know that on my 185 you can put it in and out at any time without using the clutch, which i assume means that it is a hydraulic power director.
Thanks.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:28am
Power director is the hi lo power shift.
I use my brother's 190XT Sereies III Landhandler (just love that name) for baling and it's the one I prefer and the only one my wife will drive.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 9:46am
Al I mean the 175 has the manual PD(hi,lo)and the 200 has hyd. activated PD wich is harder to feather it to a slow smooth engagement from a stand still. You will have the PD in neutral,shifter in gear,PTO engaged and let out on foot clutch to start pto then use PD to start tractor movement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:00am
Actually, the hyd pto is an option and not all 200 are so equiped.  The 74 200 we had did but a few years ago we bought a 75 200 from the original owner does not, it is the manual pto.  I turned Andy loose with the 200 when we was about 9 and he wanted to have a tractor back like the first one he drove.  And yes, the hyd pto will not feather and it will shear safty bolts starting a bailer from the suden jerk when engauged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 11:12am
Ok, are there different style levers that one could tell ( just by looking ) if the pto was hydraulic or manual ?
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 12:47pm
We had a late model 200 on the farm that was our big horse for 10 years we put many hours on this tractor with few problems. I would try to get a late model with the short power director lever as they do have better brakes in them, In my opinion a great tractor. If you can do what I do to mine without totally destroying it they must be a good machine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 12:55pm
I was talking about taking off moving with the PD(HI and LO). I forgot about hyd. engage on some PTO's. I've never had one with it. With one of those you don't even have to push the clutch in and if Iam not mistaken my buddies has a PTO brake also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 1:32pm
The hyd. PTO clutch is controlled by a short lever located at the lower rear side of the console to the right of the seat. The manual PTO is controlled by a lever sticking up through the floor on the left side towards rear of battery box. And as another post read,get a newer model with the short PD(Hi-Lo) lever. They are the easiest and smoothest shifting PD that AC ever put on any tractor. Also I love the Hyd. PTO engagment on mine. I know another post said they engage too quick,but mine engages nice and slow if you pull the lever up slowly. If you have an older round baler like mine that requires the PTO to be disengaged to dump the bale,the manual PTO would be a pain in the butt and require depressing foot clutch every time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 1:40pm
Ok- short lever on the right side, thanks, this will help. My 185 has both hydraulic actuators on the power director and the PTO and they shift smoothly in and out all of the time.
Thanks again.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 2:18pm
I'll throw in my 2 cents. If I was to decide on my farm which tractor to bale hay with...the 200, no doubabout it. I baled with the 170 just to say I did and to show my son in a pinch it'll work, but on my hills and with big kicker wagons, the 170 worked her guts out and a 200 would pretty much play, around here anyways. Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 2:55pm
Yes the pto leavers are different. The hyd is a small leaver on the right side (between seat and consol).  The manual is on the left, big leaver, comes up out of the floor like the later 190.
