B/C belly mower
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: B/C belly mower
    Posted: 22 Feb 2012 at 11:40am
Are b and c belly mowers the same? If not, how hard is it to mount a b mower under a c?
Can't fix stupid
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 11:53am
If you mean sickle bar mowers, there is no difference.  Rotary mowers are something else entirely.  Woods brackets are different between the B and the C/CA to allow for the different distance between final drives.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 12:46pm
Some of the Woods belly rotary mowers have an adjustable pipe on the frame that allows you to put the mower on a B or a C/CA and some do not. I have had both.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 12:58pm
good to know
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 2:18pm
So the mower don't matter its just the brackets right?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 2:28pm
Yes, the only difference is the cross tube push bar that bolts to the final drives. Mine is a 3 piece that will fit B,C, or CA.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 2:38pm
When the CA came out the number 5 mower was developed.  It was basically a B-C mower that was adapted to fit either the B-C or the CA.  Only thing needed to make the changes was the kit for the B-C lift arrangement and the kit for the CA lift arrangement.  Since the final drives on the CA were angled to the rear it made it a little longer so there was a two position for bolting the mounting brackets on the mower frame.
The B-C sickle bar mower was the same for both.  I sure mounted enough of them.  In fact, when we sold the B and C for quite some time it was the only mower available.
Rotaries were yet to come.
Sorry I got a little windy but the question brings back some very good memories.
Good Luck!
Bill Long
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 4:00pm
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 5:36pm
I would like to find one of those "multi-fit" mounts to use on my B. if anyone has one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 7:44pm
If you have a B or a C mount, you could do it with a torch or cut-off saw and some new pipe.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:07pm
I've got all the stuff with a 72" Woods deck that came off of a C... unfortunately, I have two Bs and no C (the mount is non-adjustable). I don't really approve of using these tractors for yard mowing anyway... there's real work to be done with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 10:12pm
mine is a 59 inch on a B.. It had C brackets and i cut and welded to fit the B
This page was generated in 0.031 seconds.
