#77 Rake Teeth Clips
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: #77 Rake Teeth Clips
    Posted: 21 Feb 2012 at 7:00pm
I posted this on the classified link without any responses, so wanted to run it by the forum.  I am in need of the clips/brackets used to mount the teeth on a model #77 rake. They are approximately 4 1/2" long and 1 1/4" high. Here is a picture of what I need. I need about a dozen of them. Agco can get them for $8.47 each or some aftermarket they have for $5.36 each.  Would like some used ones for a little less.  Either respond here, PM me, or if it is easier you may call my cell at 402-540-5987.  Also, if someone has a manual for the #77M rake it would be appreciated.  I need to figure out how to adjust the height.  I think it is on the rear wheels, but would like to confirm.  Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 8:50am
Going to bump this back up to see if there is any response.  If I can't locate these clips used, I'll probably have to go thru Agco and pick them up.  Unfortunately, I need quite a few which tends to add up when buying new.  Also, I'm interested in a manual for the #77M rake.  I think I've figured out the height adjustment, but would like to confirm via a manual.  Thanks, Dave
Fastcars63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fastcars63 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 10:29am
Since it already has some rake teeth from New Holland would the clip that holds them to a NH rake work. I understand if you are wanting it to look original and want the OEM.
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 11:28am
You could give these guys a try: http://www.sloanex.com/hay-and-baler-parts.html?cat=2928. Sometimes the AC rakes and the New Idea rakes parts would interchange.
Dave
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 11:52am
I know they wouldn't be original, but what about the single teeth clips like for a new holland rake and just use one per tooth.
farminharmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 12:12pm
To use the new holland teeth you will need to redrill the holes in the bar because the bolt sizes are different for new holland and you cant keep the teeth tight with the smaller bolt.
B110 CA D10II (2)D12III 5040 5050 6080 170
JD5205 Kubota M9000 Kubota M95S
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 3:54pm
i use NH1 teeth on my 77G thay fit perfect with 5/16 carage bolts . i got new clips for mine from AGCO.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2012 at 5:38pm
You might be able to buy steel channel bent to that shape. You would have to drill holes and cut the notches. As long as your labor ain't worth nothin you might save a little.
This page was generated in 0.073 seconds.
