removed governor rod spring on '47 C
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Topic: removed governor rod spring on '47 C
    Posted: 21 Feb 2012 at 9:56am
I decided to take the governor rod spring off the rod since the carb and engine seems to "flow" much better without it. Does anyone know of a downside to this? Will it hurt anything? I only use it to drive around and mow my lawn. I don't pull anything heavy with it or work it to death.
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:06pm
bump
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:48pm
What that spring is for is to smooth out the surges in the engine under light load.  Most governor rods (run across the front of the engine) eventually gum up a bit, and then the spring is no longer needed, because the rod no longer moves "too" freely.
Still in use:
