ac help with id
bobsouthernky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Topic: ac help with id
    Posted: 02 Dec 2009 at 7:48pm
 called about an AC tractor today. He said it has been restored but no decals. He don't know what he has.    AC tractor no in front of gear shift 200931. Motor number 33019-31. Narrow front. Hand clutch and foot clutch. Any ideas What it is or worth?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 7:55pm
If the # by the gear shift is the tractor #, it should start with a letter, which would be the model. Otherwise it is probably a casting #.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 8:04pm
Ok Guess I will go see for myself. That was all the information i could get from him, after 3 calls. He said he traded for it and know much about it. Maybe I will know more after weekend. Where would the serial no. be located on a wd or wd45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 8:10pm
Standing behind the tractor, look on the left side of the rearend there is a flat spot about 5 inches below the brake inspection cover. There will be a # stamped in starting with WD.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 8:58pm
if the tractor #, serial # is by the shifter and it has a foot clutch and a hand clutch then it is a CA. But the serial #'s don't go that high for the CA.  Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:29pm
Some early WD's are stamped to the right side of the left brake cover.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:38pm
How can someone restore a tractor and not know what model it is??
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 10:04pm
To some people, restoring means to paint, no model # required.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 6:52pm
It is possible that it only got paint. The owner traded for  it. He didn't do anything to the tractor. Only drive it from road to barn. It could be anything even not ac. He said it was 5 speed. Factory 3 point hitch. Wet lines. No decals just paint. Will know in a couple of days.Thanks for info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 9:21pm
If it's a 5 speed with factory 3 point, my first guess would be it's not an Allis. If it's sort of orange maybe it's a Case or just totally the wrong color. Check under the tractor by the bolts on the top lip of the oil pan or hard to reach spots under the radiator for places where they may have painted over some grease and oil. Sometimes paint will hold the oil back for a while and after you put some miles on it the leaks show up. Learned that from experience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobsouthernky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 9:24pm
This is a wd snap coupler hitch. Has a 3 point put on it.Rear tires about 60%. front tires 90%. Paint good but some small dints in hood. Battery box not complete some rust. No leaks detected. Gas engine. Now now the question. What is it worth if it runs ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 10:59pm
So was it a 4 speed, not a 5, or is it 5 with reverse? Is it a narrow front or wide front and are the spinout rims on the back rusted at the valve stems? Around here with good rims and a narrow front maybe $600-$700, a few hundred more for a wide front. Do you know what the serial # was? WD and WD45 both start with WD.
