photo bucket test fire 1
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Topic: photo bucket test fire 1
    Posted: 17 Feb 2012 at 9:03pm
here we go i copyed image then tried insering a picture in the post box but the URL code dont allow it to come through?
Angrywhat am i missing here fellas need a computer guy or gal to make this easyier for a country boy in way over his head?????????????????????????????????????Ouch
~AMP~
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:19pm
You don't copy the image, you copy the IMG code all the junk and including the [IMG] brackets. Look for a box that say LINKS and copy the bottom one. Paste it in with your text.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:29pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:32pm
Testing photo links.
If they work this way it will save some fooling around for sure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:40pm
Wow! That is a huge improvement!
Will this allow photobucket videos to work?
probably not. Edit-Nope, but it makes a nice clickable link.
And now for my last trick, let's try a slide show.
"And now, Rocky, watch me pull a rabbit out of this hat!"-Bullwinkle
Edited by redline - 17 Feb 2012 at 11:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:45pm
Yup! Click the picture and it takes you to your photobucket page and the video starts up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 7:59am
Here is a clip I have on photobucket. Do the same thing, copy the IMG code and paste in with your text.
Guess I can't do itConfused
Edited by CTuckerNWIL - 18 Feb 2012 at 8:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 10:28am
Somehow this message board will embed youtube videos, but it resists all attempts to embed photobucket videos, and I am not bright enough to figure it out. Oh well, it is alot of fun posting photos anyway.
Sorry, got a little carried away with the photos!
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 5:23pm
Did that grain cart just sink in the ground or is there some ruts we can't see.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 6:08pm
It pretty much just sank there. We had driven through the area before, but this must have been one time too many. It brought the cart tractor to a dead stop. We still don't know why there was a soft spot there. It has never been a problem before or since, and the man that was running the cart is the man that farmed this land before me, and he didn't know of any reason for the bottom to drop out either. The field was not soft, as we were able to drive trucks out to the cart and we put half of the cart load on each truck, and then drove the trucks out. Just another one of those mysteries, I guess!
Edited by redline - 19 Feb 2012 at 6:16pm
JOHN N/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 6:17pm
Redline how do you post pictuer after picture on the same post,thanks John
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 6:45pm
After you have your photos loaded onto a hosting site, I use www.photobucket.com, you find the photo you want to post, hover over the photo with your cursor until a box pops up under your photo.
That box will have choices for email &IM, Direct link, HTML code and, the one you want, IMG code. Put your cursor over the gobbledy gook in the box and left click. It should tell you it copied in small print. Then go to your reply box and right click the mouse and select the "paste" option. The reply box will have a bunch of writing that looks like this:
http://i84.photobucket.com/albums/k31/redlinefarm/100_9218.jpg
(it will have Img in brackets)
But this is what actually shows up in this instance.
 Hit the return button, or else the next image will be placed next to this one rather than below it, and go back to photobucket and repeat the selection process. Return to your reply box and do the right click and paste routine again.
I usually have multiple windows or tabs open, so clicking back and forth between a tab with photobucket open and the reply box here is pretty simple.
Edited by redline - 19 Feb 2012 at 7:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JOHN N/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 6:57pm
Ok i will try it sometlme ,very nice pictures by the way.thanks John.Is that a 210 in the shop looks cool in that photo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2012 at 7:16pm
It is a Two-Twenty, sn 2072. I hadn't gotten around to painting at this point. The stuff is lined up in the shop and things are tidied up in preparation for a group of us old iron nuts that get together at someone's shop/garage/whatever to have coffee and sling BS once a month. It probably is about my turn to have the group over-the shop could use a good cleaning, and having company is great motivation!
I added one more photo to previous post, I hope it helps.
I figured out what to do, I just have a difficult time explaining it. That must be why I am not a school teacher.
