d17 oil pressure
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Topic: d17 oil pressure
    Posted: 17 Feb 2012 at 7:42pm
How much oil pressure (in PSI) should my D-17 gas have when warmed up? Mine seems low but it just may be me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:33pm
Full flow oil filter or old (WD) type?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:41pm
Tony, early D17's had the by-pass oil system just like earlier tractors. They run anywhere from 5 to 15 psi, most are on the lower end after years of running. The later 17's had a full flow lube system with a different filter and would probably run higher psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:29pm
Full flows run 30lb cold or hot with 10W30
