Engine Upgrades
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Engine Upgrades
    Posted: 17 Feb 2012 at 1:12pm
Anyone know any tricks to get more power out of an Allis C? I know they aren't designed to have a lot of power but I was thinking a little more balls would be nice.
Can't fix stupid
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 1:21pm
you need to talk to Dick L and read some of his previous posts.  i seem to remember something about putting a D10-12 crank in a C and some other mods
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 2:59pm
Stick a D15 series II motor in it.
"Burgie"
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 3:20pm
i seen a puller from Iowa that put a super charger of a 3.8 gm engine on his pulling tractor made great power to good actually case he broke the rim and tire right of the side of the tractor when he took off down the track had to drag it side ways to clear the track i would have been so embarrassed but that's part of it
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:37pm
If u put a D series engine in it do u have to put special supports on It to hold the engine or does it bolt in the same way?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 9:41pm
Easy fix? install a larger carburator from like a D15 or D15 II.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:09am
No special engine supports required with the 138, 149, and 160 engines.  Having said that, I have seen 170+ cubic inch engines that were based on the 125 block. Probably 55-65 HP.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 8:48am
So if a person were to put one of those engines in an Allis C, one could consider that C to be one Mean Orange?
Can't fix stupid
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 9:19am
aj. you could tell everyone you have a C+ !
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2012 at 9:41am
Ha!
Can't fix stupid
