190 XT 18.4-38 tire conversion
GARY1967 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY1967 Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT 18.4-38 tire conversion
    Posted: 17 Feb 2012 at 11:15am
Hello
I currently have a 190 XT with 18.4-34 tires that need replaced.  Rather then replacing with same size I am asking is there an easy way to go with the 18.4-38 rims and tires.  I've heard or been told this could be done but I cannot find out or learn how it is completed.  I want to keep the current hubs that I have, I just want to change rims and tire size.
Thanks Smile
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:17pm
Two ways, if you don't need Power-Adjust wheels.  One is called "step-up lugs" that are taller cast pieces to connect your 34" hub to a standard 38" rim.  Another is called "drop-center" rim that the center is 34" to work with your hub and cast pieces, but outside is 38" to hold a 38" tire.
If you want to have power adjust wheels you will need to change to 38" cast centers.
Step-up rim from Unverferth:
Edited by Russ-neia - 17 Feb 2012 at 1:31pm
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:28pm
I have 38" centers off of  a D19  that I would sell...not sure if they would fit your 190.
ALLIS EXPRESS!
This year:
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:40pm
I don't mean to step on his thread but can you use the step up lugs on 38's and be able to put 42's on? I would think you could but I've never heard of anybody having the longer lugs for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:53pm
KGood,  Yes, you can use the step up lugs for 38" to 42" also.  They are available from any Brent/Unverferth dealer or most farm tire places can get them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 12:58pm
Thanks Russ!
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 4:36pm
I swapped my centers and rims for a set of 38"s at a salvage yard.
AGCO My Allis Gleaner Company
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 4:50pm
I have a 190 that origionaly had 34 inch wheels. It has an adapter plate and loop type 38 in wheels.
A 200 wheel center will fit also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY1967 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2012 at 2:17pm
Hello again.
I wanted to say thanks to everyone that replied to my question concerning the 34 inch tire to a 38 inch tire for my 190 XT.  I will be checking at salvage yards first and hope I have some luck.
Thanks again! Wink
Gary
