Question on WD PTO Shear Pin
hardwood61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Topic: Question on WD PTO Shear Pin
    Posted: 17 Feb 2012 at 10:03am
Just picked one up yesterday as a spare - bought tractor last year and have it stored at hunting land so I couldn't verify the size but the implement dealer said it is the right one - it is 1/2" in diameter and 2 1/2" long and ... cost $20.  Is this right?  I remember putting one in last year that the guy had in the tool box but I didn't think is was 1/2" so I thought I should ask here cause if it ain't the right one it's going back.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 11:43am
Memory fails me on the size; it wants to come up with either 1/2" or 7/16". A Grade 2 or Grade 5 bolt (right length) will also suffice as a shear pin.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 1:01pm
I use the cheapest bolts I can get and the bolt at the pto shaft hardly ever shears. They only cost about a $1.25 a pound.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 3:04pm
The bolt is a special shoulder bolt that is used.  Don't know the size.  Grade 5 or 8. 2 is too soft.
grade 5 or
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2012 at 3:08pm
It is a special bolt, as old farmer indicated, it has two dimensions on the shaft portion of the bolt.  All that being said, so many of them are so worn out, that most will take a 1/2" bolt, I wouldn't go over a standard soft bolt (grade2) if using 1/2" or it will lead to other broken parts if it ever needs to shear.  If the holes are worn out, and the thing has been running loose for some time, you may need a grade 5, just to hold since the shearing forces won't be even on both sides.
Edited by Orange Blood - 17 Feb 2012 at 3:10pm
Still in use:
