Will some CA parts fit a WD-45
lmc122 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Topic: Will some CA parts fit a WD-45
    Posted: 16 Feb 2012 at 11:23am
Will the drawbar and hydraulic unit off a CA fit a WD-45, they look identical. Is there anything else interchaingable?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 11:35am
   Why ?
http://www.rumelyallis.com
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 11:40am
Only some of the electrical.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 12:42pm
I need a drawbar for my wd45, and know were a scraped out ca is sitting that still has a draw bar and hydraulic unit. the drawbar looks the same and mounts the same as the wd45, will it fit?  The hydraulic unit in mine is missing the ball and seat in the valve body, the one on the ca looks identical. are the internals the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 12:47pm
   OK, If you can get them at a good price, go for it. If nothing else, someone else will want them !
Post Options Post Options   Thanks (0) Thanks(0)   Quote lmc122 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 12:49pm
Will they fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 12:51pm
   I don't know, if they don't, trade them.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 12:58pm
The internals of the CA hyd pump are interchangeable with the WD and WD45 pumps. Don't know about the drawbar.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 6:38pm
The CA drawbar is shorter, thinner and straight, the WD is a two piece and can be bolted around bail. It may work thought if you want to try. The pump itself is the same, the linkages are not.
Leon B MO
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 7:20pm
neither will work. ca drawbar is much lighter. pumps look different to me.
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 8:41pm
We have a non snapcoupler wd drawbar on our CA that is bolted around the horizontal iron piece. Sticks out a bit more but is nice to use as a step to get on tractor. It had to be modified a bit at the front anchor point.
Edited by Steve(SEMN) - 16 Feb 2012 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 9:59pm
Some parts of the pump  are the same  but the pump housing is different.  MACK
