56 CA Noise From Hydraulic Pump
Mike(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Topic: 56 CA Noise From Hydraulic Pump
    Posted: 02 Dec 2009 at 5:21pm
I have a noise coming from the hydraulic pump (?)  on my 56 CA.  When the PTO is not engaged I hear a rattling sound or maybe a sound of gears not fully engaging.  When the PTO is engaged I cannot hear the noise.  I did not have this noise until I had the transmission swapped out.  Could the noise be from the hydraulic pump not installed properly or is the pump going out?  Everything operates as it should, just this rattling sound.  Thank you in advance.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:31am
If the PTO is not engaged the hyd pump is also disengaged. Sounds like a bad bearing may be.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 12:56pm
On the CA, it uses springs under the pumping plungers to return the plungers so they stay in contact with the followers, much like valve springs keep the rockers and lifters against the camshaft. You could have a plunger that has a broken spring so it stays in and the follower could be swinging loosely making the noise. The pump is easy to remove to check it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:27pm
 Brian, if a plunger spring is broken than one would only hear that when the PTO is engaged.
 Mike, since the problem came up after you put in the trans than thats where I'd look. If you are getting the sound when the PTO is not engaged than that means it is not the hyd pump. On a "CA" you must have the PTO engaged for the hyd pump to be powered. The pump is run off the same shaft that powers the PTO. Good Luck & please let was know what you find.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 9:12pm
Dennis, I had the same problem with my CA. It depended on weather the tractor was setting level or not if one of the followers would rattle or not.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 9:42pm
In your post you said "sounds like gears not engageing". Might try pulling the PTO lever as far back as posible, maybe the shift collar is not disengaging far enough away from the gear. When the pto is not engaged does the pto shaft have a vibration like what your hearing in the pump? As the other guys said when the pto is not engaged the hyd pump is sitting still. If the bearing is going out of the trans output shaft, it might not make noise when the pto collar is slid forward releiving the sideload. Does it make the noise reguardless if the tractor is in gear or idling out of gear. If it makes noise ( by the pump )  while tractor is running, trans out of gear and pto out of gear, it might be the bearing on the end of the trans output shaft or the trans shaft output bearing. Good luck and keep us posted.
Leon B MO
