frost teeth
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: frost teeth
    Posted: 02 Dec 2009 at 2:45pm
broke a frost tooth on my 816 back hoe bucket. Is there a weld in replacement.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 7:14pm
Did you brak the shank or the tooth. There are several types of teeth , pin on and crimp on as most common.
 The Pin on use a wedge pin with a compressable rubber between two metal pins , this drives through tooth through the hole in shank.
 frost teeth come in different designs also with single , double , or other configuration . They are hard but wear faster it seems than regular teeth.
 If you broke the shnanl from bucket, there are weld on shank mounts that can be welded back . These come for the pin type tooth or the crimp type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 9:49pm
broke the shank,  picking rock. Are the shanks unversal\, or do I have do some looking for one that matches
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 8:17am
Shanks varry by mfg. On my 715 I ended up gpong to JD construction dealer as they had a large supply of many different brands to choose from.
 Could try someone like Empire Bucket in Hudson WI to see what they stock .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 2:00pm
Do I have to annel the the weld area, after welding the new shank in
Edited by Dave A - 03 Dec 2009 at 2:01pm
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 6:16pm
Nope just cut off old , grind area clean, slip new weldment on and use good root pass and finish with 7018 . (E70S wire)
 Are you using frost teeth or just teeth on bucket?
Many people use a piece of cutting edge with pockets  to fit over teeth, this gives a cutting edge to grade with or make a smooth bottom trench. Blade can be couple feet bigger than bucket or same size, depending on use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 6:44pm
took the shank and chunk of the bucket out. Have pinned fost teeth. Will have to replace some of the bucket in that area. Don't want it to crack again in the heat effected area. Is there anything speciel about the steel in the bucket.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:39pm
Many buckets use AR steel plate in the mfg. but there are also the mild steel sheet units out there . On mine I welded wear strips to back and sides to slow wear on bucket it'self. I also added to the edge another piece of cutting blade to add some width as I dig 36" trench for drainfields.
 In most cases no heat-treating is needed as the strain isnt that much or the shock load isn't constant. It is easy to break things though as you found out by overstressing one part. I bent one cylinder breaking a old footing by pounding on it with bucket, $ 500 lesson that i lerned not to do again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2009 at 7:55pm
thanks for the help.
Winston Churchill
This page was generated in 0.190 seconds.
