Hand Clutch
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: Hand Clutch
    Posted: 12 Feb 2012 at 8:51pm
I have a 1953 WD #143391 with the WD-45 rear end with the 2 disc hand clutch. Can I put a WD-45 3 disc clutch back in it's place? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 9:37pm
Yes.They are interchangeable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:41am
May not release good because the shaft is worn where the 2 disc have been and 1 of the 3 will be in old grove 2 will be out of worn grove. Have done it before and has never released good.   MACK
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 7:48am
We have have put in several 3plate clutchs in 2plate tractors and never had a problem.
