Adjusting a Governor
Brian in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian in MI Quote  Post ReplyReply Direct Link To This Post Topic: Adjusting a Governor
    Posted: 02 Dec 2009 at 8:08am
My Gleaner E combine the Govenor needs adjusting and I don't know how to go about it.
The problem is the Governor is slow to react. If the engine is under a heavy load it is ok like combining and traveling up grade.  The problem is if I travel down a slope where the engine is not under a load and turn around and go back up the same slope the engine will pull down to 1400 rpm before the gov brings it back up to 1650 rpm. I have tried adjusting the linkage from carb to gov rod as per the manual and by shortining the rod it makes it worse, pulls down to 1100 rpm.
Any help is greatly appreciated,
thanks
Edited by Brian in MI - 02 Dec 2009 at 8:19am
FRANKO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FRANKO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 11:04am
I do not have any first hand experience with your governor but can give you some general knowledge about what might be wrong.  1.  The gain may be too low.  This is a designed-in feature that you do not have control of except to make sure you have the correct governor spring and counter weights and have the linkage adjusted properly.  2.  There may be excess friction in the system.  Look for  worn and sticking parts especially around the governor spring and the counterweight linkages.  Any ridges, grooves, or worn pins need to be fixed so everything moves smoothly.  Is it being oiled?
Ron(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2009 at 11:12am
I had a very similar problem on my D15, real slow in response, if at all. I found that there was a lot of friction in the linkage, primarily the vertical linkage shaft coming out of the top of the governor was gummed up. I cleaned it up and lubricated it with penetrating lubricant, and it was as good as new. Try that first.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
