Wheelie Bars for my pulling 45
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Topic: Wheelie Bars for my pulling 45
    Posted: 12 Feb 2012 at 7:16am
Hey there.
I just built a set of wheelie bars for my WD45 pulling tractor.
Before I put the finishing touches on them:
I have seen numerous photos of them, and they all have the small skid plates that sit horizontal to the ground, while the tractor is on all 4 tires.
Wouldn't it make more sense to have those skid plates horizontal to the ground when the tractor has it's front end in the air, so that more of the skid plates are in contact with the ground???
Any comments?
thanks.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:48am
yes, i have been to a few pulls and the skids i have seen would be parallel when the tractor front is in the air not during normal driving.  otherwise they would dig into the ground
just remember that different pulls use different rules.  Not all use napta rules etc... just make sure they are correct and safe for where you pull
good luck
Napta rule
4. Wheelie bars are required in Divisions II, III, IV & V and should not be attached to the draw bar in any way. Minimum requirements for the wheelie bars are as follows. 10" maximum above ground. The back of the wheelie bar is to extend 5" behind the tire radius. C: Pads = 5" square minimum, spaced minimum of 20" from outside each pad. D: Stabilizer bar system must be able to support the weight of the tractor in the heaviest class pulled. E: Jacking up the pads so the tractor is completely off the ground is a good test of the strength of the system’s support ability and the NATPA Tech Crew reserves the right to perform this test at its discretion.
Edited by CAL(KS) - 12 Feb 2012 at 7:52am
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:49am
Just make sure that they will skid and not dig in
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:40am
make them pivot
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 9:00am
Originally posted by d17brown d17brown wrote:
make them pivot
PIVOT, yes, I like that.  thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 3:26pm
Pivoting.
Aren't they Purdy??
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 4:42pm
looks good
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 5:27pm
good luck
Napta rule
hey CAL(KS), these were the exact rules I built them buy, but they just didn't say what angle to make the plates.
Pivoting works!
Thanks!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 6:41pm
Deeree
Hate to burst your bubble - but looking at your picture - and understanding that they pivot - I believe if the front of your tractor raised up to the point that the wheelies contacted the ground, the front / leading edge would dig in and cause the foot to flip around and end up on top of the square tubing.
Again just my opinion from looking at your picture.
Gary
NickT(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NickT(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 6:49pm
If you angled or beveled the front of the pad that would work, right?  Out riggers on trucks are made that way so they will slide and not dig.
pabob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pabob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:00pm
I agree with gary,  i made a set that pivoted and they did roll over and made 2 nice furrows in the track at the most inoppurtune time.   matching the angle to the expected front end height is the way to go. remember the kiss method.   (keep it simple stupid)
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:05pm
its hard to see, but i've got the tubing cut so that there isn't much travel in the pivoting.
It sits level now, and bends back (which would be level if the tractor was in the air, but won't go any further.
The steel is 3/16, and as long as the grade 8 bolt doesn't sheer, I think it will hold the weight of the tractor, and not allow the plate to pivot back any further and dig in.
Thanks for all the input.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:55pm
  they should be angled these were built with the front wheels 42 inches off the shop floor with a slight angle to keep the front edge from digging in i personaly dont care for the pivioting padsd  when they hit the ground what is to stop it from digging in and then flipping back and essentialy chocking the tractor and probley breaking somthing and getting dangerious
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 8:42pm
Don't make them pivot. Like the others said if the back flips up you will have a anchor. Role the front edge up, weld them solid to where the back edge hits the ground first.  MACK
This page was generated in 0.097 seconds.
