What are these Disc and Rake Models???
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Topic: What are these Disc and Rake Models???
    Posted: 09 Feb 2012 at 10:07pm
Im wondering what models are the following disc and rake???  Im thinking the disc is a 211 and the rake is a 77???
Edited by 1953CA - 09 Feb 2012 at 11:19pm
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 8:21am
That looks like a 200 series disc.  I know nothing about the rake.
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 8:33am
Rake is a 77M.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 8:38am
That is a rare rake to find.Not many made to start with. Most were converted to pull type. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 7:49pm
I confirmed the disk to be a model 211 - Options are - a snap coupler hitch, 18" notched disk in the front and smooth in the back.  Does need one bearing though.  Does anyone know where to get one?
And the rake seems to be ready to use as is, maybe a bit of grease needed...Does have a top link bracket so I could use it as snap coupler or 3 pt.  Very interesting.
So I didnt make out to bad in the deal also bought the 80R sickle mower with 3 sickles and they threw in the 3 bottom plow for free.
smokey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smokey Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 6:29am
You'll like that 77M rake mine does an nice job, but I've only used it once but when I get the WD done I'am going to put the rake on that, also if you use the rake give yourself a little room on the corners in the field or you'll be fixing fence it swings wide on turns, LoL.
Nice find by the way, like Tracy said !
