Can I bolt up 185 finals to a 175?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Can I bolt up 185 finals to a 175?
    Posted: 09 Feb 2012 at 2:49pm
The reason I want to is I have a good set of brakes for a 185, but the 185 uses the small spline for the brakes. Is the gear ratio the same?
ALLIS EXPRESS!
This year:
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 3:08pm
hmm, I thought the 175 - 185 were the same - 170 is different.  Some of the bull widths were different but were replaced with wider gears best I remember.  Sure you do not have a 170 ?   70241775 is the axle that splines into the diff spider gears on the 175 and 185  right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 3:27pm
Actually I tore down my parts 170 and saw the difference in the diameters and assumed the 175 was the same  (my IT manual was for a 170). So....I guess I am all set to tear into the 175.  Still curious tho, since I have a 170 also...
ALLIS EXPRESS!
This year:
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 3:32pm
Eldon, you sure are doing a lot of wrench turning! LOL
Edited by JoeO(CMO) - 09 Feb 2012 at 3:32pm
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 4:37pm
!70s are different than the 174 and 185.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 10:37pm
Gear Ro on 185 is just a little slower than 175. Brakes are the same. No advantage for all the work.  MACK
