What would you do?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: What would you do?
    Posted: 09 Feb 2012 at 1:33pm
I recently parted out a 185D that had transmission and other problems. I was hoping the motor would fire up, but as it turns out it is stuck. The oil isn't even black in it and I think it might just be locked up from sitting. I'm debating whether to sell it as is, try soaking it, take the head off and take a look inside, or just part it out. Any suggestions?
ALLIS EXPRESS!
This year:
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 2:05pm
pull injectors and soak that way
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 5:15pm
Eldon, you should probably fix er up. Hate to see you be short a tractor when spring work gets here! LOL! Darrel
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 6:08pm
If you don't try, you'll always wonder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 6:28pm
Eldon - I'd part it out but keep it...way too many parts you can use on other tractors you have.  How many times have you sold parts you wish you had now????  ;-)  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 6:51pm
The tractor is parted out....I'm just wondering if I should sell the engine as parts.  Even if I get it un-stuck I have no way to run it to see how it runs. I figure the head, injectors, pump, crank and block are probably worth more than what the engine would bring as is.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 7:06pm
Part the engine out , lots of guys on here could probably use the parts. The tractor sounds like it is not going to run again so the parts it provides can help another to keep going.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 7:24pm
Clap
pull injectors and soak with a 50/50 mix of  acetone and atf
and then if you do part it out , you have more moving part`s
to sell or used and very little expenses  one qt of tran fluid
and a qt of acetone one or two week . you decide
              HTH      B:-)    Dnoym
