To orangeblood |
nevans
Joined: 06 Dec 2011 Location: Red Bud. IL Points: 837 |
Topic: To orangebloodPosted: 08 Feb 2012 at 8:48pm |
Anthony here are the distributor numbers I found so for 112609/6h15,1111412/9k3,1111745/7a15,1112593/12k4,1112584/7L13,also I have a single groove and a double groove pulley with the front drive bolt holes hope this helps in the rebuild niel
Orange Blood
Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Posted: 08 Feb 2012 at 9:16pm |
The 1112593 is the right model number, the 12K4 doesn't look right, it should be one numeric number then a alphabetical letter, then one or two more numbers. Could you look at that one again. What about a water jacket sending unit plate?
Thanks, Anthony
Still in use:
HD7 WC C CA WD 2-WD45 WD45LP WD45D D14 3-D17 D17LP 2-D19D D19LP 190XTD 190XTLP 720 D21 220 7020 7030 7040 7045 3-7060 Projects: 3-U UC 2-G 2-B 2-C CA 7-WC RC WDLP WF D14 D21 210 7045 N7 |
