190 XT Power Director |
Post Reply ![]() |
GARY1967 ![]() Bronze Level ![]() ![]() Joined: 04 Feb 2012 Location: Indiana Points: 106 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Feb 2012 at 4:35pm |
I recently purchased a 1966 190 XT with a gas engine, SN9561. It set for maybe 10 years, more to less when I purchased it. Since buying this tractor I then starting reading posts in this forum and is there something wrong with the power director for these tractors? Mechanic has the tractor running and it sounds really sweet. But after reading the posts in this forum I wondering whether to stop where I am with it or continue to restore it. The pan been taked off and all is well with the bearings and etc. Resurfaced flywheel and replaced clutch thus far. It still needs tires all around. Sheet metal is excellent. So anyway can anyone comment what I need to watch for with this Power director? Can it be shifted from low to high while in motion?
Thanks
ctbowles58 ![]() Orange Level ![]() ![]() Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
i would try it first it maybe ok. and yes you can shift on the go "shift it fast" back =low..... middle =nuteral...forward = high range
Edited by ctbowles58 - 08 Feb 2012 at 6:15pm |
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Make sure its full of hyd. oil and give it a whirl , Only thing with setting that long the rubber -o- rings get hard and wont seal good ; i,m working on a 200 now thats been seting and running into alot of oil leaks ; the Powerdirector in a gas tractor should be good shape , but over time the high side clutches do break
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
These Power Director clutches are very strong and capable of some abuse, but remember that everything wears out at some point and we are talking about tractors that are 40 to 46 years old.
1969 190XT series 3
Post Reply ![]() |
