7045 fuel sending unit
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: 7045 fuel sending unit
    Posted: 06 Feb 2012 at 8:09pm
I got one from agco and can't get it to work. I think it hits the baffle in side the tank. I put it in the same direction as the old one came out. It only reads 1/2 tank all the time. I went by the directions to install it. Anyone else have done this ???    Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:13pm
 It is possible you might need to bend the wire arm a bit to prevent rubbing the side of the tank if that is the problem. Compare position of the float of the new to the old sender.
This page was generated in 0.813 seconds.
