d17 power director filter
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Topic: d17 power director filter
    Posted: 05 Feb 2012 at 12:15pm
Series 3 diesel any one know the what the filter # used?
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:44pm
Mine is a ser.3 gas and I use same filter for engine oil and power director---NAPA gold 1515
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 12:56pm
Thank you ill go get one
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 1:20pm
OK guys, where is the PD filter located?
I thought there was only a screen!
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:11pm
Mine is a diesel and its on the right side just above the. Pd cover brooch the fuel tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:18pm
OK,  mine's a Series II so I guess it doesn't have that nice feature!?
Edited by Brian G. NY - 06 Feb 2012 at 8:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:20pm
The feature mine doesn't have is brakes .....yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:41pm
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 3:14pm
Series I does not have that feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 4:21pm
Wasn't it about series 3 that they started putting P.D. filters on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 4:48pm
Brian - yes Series III @ SN42001.  They also combined the PD and hydraulics compartment at this time.  Series III held 24 quarts, Series IV 26 quarts (since the internal Hydraulic pump was removed).  Filter crosses to Fram PH11 or Baldwin B9.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 5:00pm
Will ph8a also work
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 5:03pm
PH8A is the correct engine oil filter.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 5:10pm
Actually now that I think of it there was a SN break where the early ones used the same hydraulic and oil filter...(now why they changed it I have no idea).  I think a PH8A (Or Baldwin B2 or Motocraft FL1A) will work for SN42001-SN68627.  SN68628 & up used the different filter.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:37pm
Fram PH 11 for hydraulic filter.  PH 8A for engine oil filter.
Longmeadow Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Longmeadow Farm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:44pm
I own a 175, bought it new in DEc 1980. It was shipped from the factory with the same oil filter base for both the engine and hydraulic system. They boith take a PH 8A filter.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:01pm
The serial number break was during Series III production where the hydraulic oil filter changed.  DOn't remember exactly the number.  However, the earlier ones took the same filter as the engine, a 70237000.  These have I believe a 3/4 inch hole where the threads are.  The newer ones I believe have a 13/16 hole and is the same hydraulic filter as used on, for example, a 185.
Here is picture of the location of the hydraulic/power director oil filter on a D17.
Edited by DanD - 05 Feb 2012 at 11:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:26pm
mine is one of the real early series 3's it has old style brakes and new style pump timing (i think) cant find the hole to put the pin in the flywheel and the pulley doesn't have the timing marks on it,.... so i guess ill take it off and see what size the threads are.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:33pm
All Series III tractors have the new style band/disc brakes.  Don't trust decals to tell you for sure if your tractor is a Series III or not.  WHat is the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 12:17am
42043 when i took it apart the brakes had the 2 piece pull the pin and take them out of the top of the hole brakes i dont think it has discs
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:18pm
well i dont think its a ph8a the one thats on there is @ 1 inch longer
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:41pm
I just changed the filters on my 170 and it takes Fram ph8a or baldwin b2 for both.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:41pm
cool ill try it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 10:48pm
When I got the tractor a year ago it came with a fram ph11 which is a inch longer it was bought by the previous owner but not installed. I went to use it and it wouldnt fit. I got online and the fram filter application guide showed it took a ph11. Local parts store sells baldwin and by application and cross reference from the agco # they showed it as a b2 or ph8a.
Allis Express
