AC G block repair
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC G block repair
    Posted: 04 Feb 2012 at 8:52pm
What is most common method to fix the drawbar mounting holes in engine block? I have a block that holes are cracked thru case. I know there are many been fixed. What is the best way to do it? Tracy Martin
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 10:46am
In my eyes the only option would be to have it welded. You would want a welder the realy knows what he is doing.
The universal answer to all questions is yes, how much do you want to spend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 1:33pm
I thought about making a threaded carbon rod, and screw it into a pre-heated block. Weld it with nickel rod, slow the cooling down, and clean it up when cool. I figured there would be several opinions on the fix, but I guessed wrong.Tracy Martin
Edited by Tracy Martin TN - 05 Feb 2012 at 1:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 2:59pm
If shipping wasn't an issue, buying my block that needs a $40 sleeve installed could have been a viable option......sigh...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:06pm
Sounds like you know what you are doing.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:46pm
  welded a nose castring for a DC CASE TRACTOR HIGH CROP  WAS STILL ON THE TRACTORwhen sold with no complaints  weld lots of cast parts  welded a snapping roll on a corn picker one time was still on the picker a year later after many acres  had  4 threaded holes in it[ ac left hand point]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 6:47pm
I am interested in a couple of blocks if need nothing but boring cylinders. Sleeving if necessary. Tracy Martin
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:23pm
Short of a replacement used block, I think this would be the only way to be able to use the drawbar again
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 10:49pm
Joe, it was a weak point for sure. Loose bolts are what caused these problems or failure of front attaching pivot. Seems every other one is cracked or repaired. Alot of trouble to fix properly. Tracy Martin
