arps half track D-14
daughter#1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daughter#1 Quote  Post ReplyReply Direct Link To This Post Topic: arps half track D-14
    Posted: 04 Feb 2012 at 8:25pm
Found lit on Half tracks for wd thru d-17 Was wondering is anyone had any experience with them?? The lit claims up to 488% traction increase. The cost was from 452.00 to 527.00
Sorry the pic is not better, someday will buy a scanner.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 8:39pm
there are several of those around and there are a few pictures on this forum, I'm sure someone here will chime in soon
Edited by Bill_MN - 04 Feb 2012 at 8:39pm
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 8:43pm
Here is my 1954 WD45 with AARPs, I've never used them to their full potential but you can sure go over soft ground with them.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:03pm
are those hydraulically loaded? On the WD45, I see a cylinder of some kind on the far side on the subframe.
If so, how is that done; is it pressurized "live" or pumped up and a valve closed ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 10:06pm
It looks like a hyd. cylinder but there is actually a big spring inside there for adjusting tension.
