Lift Arm Latch ID
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Lift Arm Latch ID
    Posted: 04 Feb 2012 at 7:10pm
Don't know if I am doing this right or not?  Will give it a try...  Coming from photo bucket.
Are these the early years ones?  What do they fit?  What are they worth? Thanks..
I'll be danged!!  It WORKED!!  Miracles again.  Learned sumpin new today...
Edited by Ted J - 04 Feb 2012 at 7:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:33pm
They are the earliest of them. They fit CA,D10-D12, and late B. They are the early CA latch if you want the correct tractor they were used on. I would be interested in them. Tracy Martin
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:34pm
Early CA, will fit D10/12 also. They have been bringing more than the ones for bigger tractors.....
ALLIS EXPRESS!
This year:
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 7:52pm
Like Tracy & Eldon have stated, they are used on the CA D10 & D12
These are latches that I have from Tracy for my CA
DeWayne
Flint23 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:29am
They were also used on the WD45 prior to April of 1955.
been there done that, not doing it again...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:58am
i don't think so.....the mounting is different! The wd/wd45 used a set screw to hold them on the lift arm......maybe that "style" was used....
ALLIS EXPRESS!
This year:
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 1:23pm
Is that a AC spark plug wrench in the picture?
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 2:37pm
Yes Steve! That is part of the tool kit for the tractor.
DeWayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 4:31pm
You're right Eldon, the ones I have have the set screws in them, looks like there is no hole for them in these lift latches....Embarrassed...oops
