WD help
Farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmboy Quote  Post ReplyReply Direct Link To This Post Topic: WD help
    Posted: 04 Feb 2012 at 1:13pm
I'm going to get my Great Grandpa's WD going again from the weeds and need some help.  We used it unloading the chopper wagon and other small things but been a few years since it's been run.  It's been outside but covered up and I know the motor turns over.  Was going to get new plugs and wirers for it.  Also replace the fluids and fitler.  Thing I need help is what filter number do I need for it and how much oil and what kind do I need for the engin, tains, hyd...ect.  Thanks for any help.  Will get pictures up when I get them.
Terry GA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry GA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 2:30pm
oil filter I use a fram C159 on mine.30 wt for engine and hy tran in the tranny,80wt for final drives.allot use 10/30 for the engine,but i just stick with 30wt.....good luck!
I couldn't repair your brakes, so I made your horn louder.
gman11110 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gman11110 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 3:40pm
if you are in need of a carb  i have one just ben rebuilt and tested on test motor.  i never put it on tractor.  i have paperwork on the rebuild.  it is mint..  my wd project was cancelled so i have no need for it..   also hAVE A GAS tank . it has been blasted and acid bath.  then relined  primed ready for paint.   i can make you a good deal  if you need  let me know
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 4:47pm
Find an owners manual, then later a service manual. An I&t service manual will work if you have a little experience with tractors , if not get an AC service manual. Have fun, and good luck.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 4:59pm
Farmboy...the WD engine holds (6) quarts of oil. I believe that everything else has been answered. I use 10W/30 in all of mine and I would think that Michigan is colder than where we are here in Missouri. Just a thought. Rick
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 8:54pm
here's my list of filter numbers for the WD for the most common brands, some might be outdated:
Baldwin T300-M
Hastings LF405
Purolator L30007
Wix 57011
Napa 7011
Fram C-159
AGCO OEM 70240912
Fleetguard LF571
for the air filter cup use the same oil you put in the engine
Edited by Bill_MN - 04 Feb 2012 at 8:56pm
allismanamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allismanamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 9:16pm
i got lucky and found 2 original Allis Chalmers flat top orange filters in the box yet at a auction i went to. But i am not going to put them on any of my tractors ever! i did find a Allis Chalmers brand name filter i put on my d 15 that was 20 dollars i believe i like having the Allis name on my filter though makes the tractor look nicer LOL
