Anyone converted a 185 to a 4x4
tlewis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlewis Quote  Post ReplyReply Direct Link To This Post Topic: Anyone converted a 185 to a 4x4
    Posted: 03 Feb 2012 at 7:44pm
just curios what it might take if at all possible to make a 185 a 4x4. got a sweet deal lined up to buy a 185 but really would like a 6070 or 6080 thats why i ask.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 7:47pm
It's not economically feasible to make a 185 into a FWA.  Buy a FWA 6060-6080.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote tlewis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 7:52pm
like what would economical be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 10:00pm
Like it simply cannot be done. If someone gave you an FWA axle and tires and gave you mounting brackets (which there are no mounting brackets for a 185), how would you propose to drive the front axle that needs a driveshaft???????
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 10:06pm
Listen to the doctor!  It's just not possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 10:20pm
Anything is possible with enough money!  How about a hydrostatic unit?
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 10:26pm
A 185 FWA would be totally cool, but even if you could drive the axle, you'd need a different frame as the light rails wouldn't stand up to turning and twisting from a powered axle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 10:31pm
I'm guessing this will be for a loader tractor use??? If you powered a BIG hydrostatic pump from the 1000 rpm PTO (which many 185's don't have) you'd have to switch directions with the pump forward to reverse each time. Then this pump would be sticking out the back of the tractor so you probably couldn't even use the 3 pt hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 11:00pm
Buying a good FWA 6060-6080 would be cheaper than any conversion that actually worked.
Mark
GTH-L Simplicity
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 11:19pm
I just tore down a 185 that had a loader on it...one frame rail was twisted pretty bad....definitely would be a weak area....
ALLIS EXPRESS!
This year:
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 12:05pm
You can do it by strengthening the frame rails and removing the front axle.
Get a second 185 and remove its seat and front axle.
Build an articulated  hitch and hook the two tractors together.
Attach steering brackets and hydraulic steering cylinders.
Hook up remote clutch, shift and throttle controls.
I have seen this done for other tractors but not for a 185.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 12:08pm
Or you could buy a real nice 6080 with cab and turn the key.
agcodick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote agcodick Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 11:16am
A hydraulic driven front end would probably be the easiest to do. Levy or a mud hog combine system could probably be done easily if you had a good way to power the hydraulics. Here is a 190 with a levy on it.
Edited by agcodick - 05 Feb 2012 at 11:17am
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2012 at 9:08pm
Anything is possible, but not always conventionally.  If it takes lots of inspirational words, you know it won't be cheap.  Look into County tractors from England for inspiration.  They built 1970s era Ford tractors into four wheel drives.  I believe they took power from the final drives on both sides, and ran a shaft along each side to the front axle.  I seem to remember seeing an extra housing bolted between the transmission and the rear end as well.  There's always a way: do you want to have fun and learn something or do you just want instant gratification?
karl f
jmikeyoung View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmikeyoung Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:14pm
could you use a rear wheel assist off a combine?  and has anyone ever converted a 7000 series?
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 5:37am
Those Levy set ups are pretty cool and seen on several Olivers in my area, BUT i think its alot easier to mate one up to an oliver than any other brand.  I always thought the missing 4WD D-21 looked like it had a Levy unit on the front of it
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 4:35pm
There is a D21 FWA in Gilbert Vust's museum in Portage la Prairie.  It is an aftermarket unit, possibly the one you are thinking of.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 10:41pm
 The best way to spend the least would be buy a 6080 FWA. And buy sheetmetal off of a 185, and put that on the 6080 Making the brackets for sheetmetal to fit would be alot cheaper then making FWA work on a 185.
                                                    IG
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 9:59am
But IG, where's the adventure in that? LOL
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 2:58pm
                                                    IG
I've actually wanted to see that done with a new tractor. Like get a new AGCO(MF) and take the sheetmetal off of it and replace it with AC sheet metal. I know it wouldn't be an AC but I think it would be cool. Just one of those dumb ideas that I think too much about.Cool
