18-30 radiator tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Topic: 18-30 radiator tank
    Posted: 02 Feb 2012 at 4:42pm
Does any one have good pictures of a 18-30 bottom radiator tank that they could post? I think i might have one but i don't have anything to compare it with. It is the same size as a later 20-35 but the neck for the rad. hose is straight out and not curved up. The casting number on it is C900B. I will cost a picture of it later.     Thanks Matt
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2012 at 7:18am
1927  20-35 had 3 pipece lower rad hoses 2 hoses plus one cast pipe in between made a l shape rather than going at an angle from the water pump the water pump points straight down rater than at an angle   Gary
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 5:17am
This is the 18-30 ,it has not one thing in common with a short fender 20-35.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2012 at 9:38am
The lower tank you have is from a '27 short fender 'E' 20-35. The outlet comes straight out as was mentioned and then there is a 90 degree casting that connects to the water pump. '27 'E' has a lot of differences from a '28 and up. A good friend of mine stopped by last night with an early '27 that he had just bought.   #8165,  95th short fender produced. It has the priming cups in the head, Wheeler-Schebler carb and early Eisemann GS4 mag.  Fenders are different along with above mentioned water outlet, longer governor lever etc. Transmission cover is a welded fabrication rather than stamped. I have #9114.
This page was generated in 0.395 seconds.
