200 brake lockup
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 200 brake lockup
    Posted: 01 Feb 2012 at 8:31pm
Heres the next problem on the 200 , when you step on the right brake , it locks up , no slowing down just total lock up , any pointers on this subject ?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 9:32pm
Time for a brake job.  That happened on my 175 years ago going in 3rd high while turning into the next row at the end of the field.  It was quite a ride from what I heard!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 9:37pm
Spring broken in brake, rusted on cast parts, or disc lining worn out or all the above.  MACK
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:40am
Th distance between inner and outer friction plate being out of spec can also cause lock up
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 5:26pm
Worn out disc linings will cause the lockup
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:01pm
Check your serial number before buying.  There's a split.  Early ones have the 190xt style brakes with the disc and band, some have the same style used on the 7000s with the two discs and no band.  The latter being much more expensive...
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2012 at 7:23pm
This is one of the last ones and the same as a 7000
