7045 oil leak
tnb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tnb Quote  Post ReplyReply Direct Link To This Post Topic: 7045 oil leak
    Posted: 01 Feb 2012 at 1:30pm
am preparing to paint 7045 and trying to get all leaks fixed first. both the 7045s i have leak engine oil from behind the engine oil filters hard to tell where while filters on. any ideas and how hard to remedy?   Also as far as painting am looking to end up with a tractor that am proud to drive in feild as we use this tractor quite a bit yet, not looking to win a parade or show just end up with one im proud of. How is best way to paint do we need to take rear wheals off and take off hub to paint cream hub and silver rims? tires have fluid so no small job. also to painnt the cab is it a requirement to remove all glass or can this be  taped?    thanks in advance im sure ill have more questions as we go.
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 2:30pm
Ours has the same leak, I would like to know also!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 9:50pm
Valve cover or gasket behind oil cooler.  MACK
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2012 at 11:01pm
We brush painted the wheels and rims on the tractor and it looks good. The glass and gasket holding it in can be taped off, just take your time. I start by taping paper to the glass out to the edge and finish taping off the gasket. I'd take the roof off and spray paint it at ground level.
AGCO My Allis Gleaner Company
